[PATCH] arm: Move _CPU_ISR_install_vector()
Mon Mar 18 16:31:43 UTC 2024
The use of this function is optional. Newer BSPs do not use it.
 .../score/cpu/arm/armv4-isr-install-vector.c  | 75 +++++++++++++++++++
 cpukit/score/cpu/arm/cpu.c                    | 28 +------
 spec/build/cpukit/cpuarm.yml                  |  1 +
 3 files changed, 77 insertions(+), 27 deletions(-)
 create mode 100644 cpukit/score/cpu/arm/armv4-isr-install-vector.c
diff --git a/cpukit/score/cpu/arm/armv4-isr-install-vector.c b/cpukit/score/cpu/arm/armv4-isr-install-vector.c
new file mode 100644
index 0000000000..739b02f8bf
--- /dev/null
+++ b/cpukit/score/cpu/arm/armv4-isr-install-vector.c
@@ -0,0 +1,75 @@
+ * @file
+ * @ingroup RTEMSScoreCPUARM
+ * @brief This source file contains the ARM-specific _CPU_ISR_install_vector().
+ *  COPYRIGHT (c) 2000 Canon Research Centre France SA.
+ *  Emmanuel Raguet, mailto:raguet at crf.canon.fr
+ *  Copyright (c) 2002 Advent Networks, Inc
+ *      Jay Monkman <jmonkman at adventnetworks.com>
+ *  Copyright (C) 2009, 2017 embedded brains GmbH & Co. KG
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/cpu.h>
+#ifdef ARM_MULTILIB_ARCH_V4
+void _CPU_ISR_install_vector(
+  uint32_t         vector,
+  CPU_ISR_handler  new_handler,
+  CPU_ISR_handler *old_handler
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Warray-bounds"
+  /* Redirection table starts at the end of the vector table */
+  CPU_ISR_handler volatile  *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
+  CPU_ISR_handler current_handler = table [vector];
+  /* The current handler is now the old one */
+  if (old_handler != NULL) {
+    *old_handler = current_handler;
+  /* Write only if necessary to avoid writes to a maybe read-only memory */
+  if (current_handler != new_handler) {
+    table [vector] = new_handler;
+#pragma GCC diagnostic pop
+#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 65f1ad2014..c27f4de9f9 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -8,8 +8,7 @@
  * @brief This source file contains static assertions to ensure the consistency
  *   of interfaces used in C and assembler and it contains the ARM-specific
  *   implementation of _CPU_Initialize(), _CPU_ISR_Get_level(),
- *   _CPU_ISR_Set_level(), _CPU_ISR_install_vector(),
- *   _CPU_Context_Initialize(), and _CPU_Fatal_halt().
+ *   _CPU_ISR_Set_level(), _CPU_Context_Initialize(), and _CPU_Fatal_halt().
@@ -160,31 +159,6 @@ uint32_t _CPU_ISR_Get_level( void )
   return ( level & ARM_PSR_I ) != 0;
-void _CPU_ISR_install_vector(
-  uint32_t         vector,
-  CPU_ISR_handler  new_handler,
-  CPU_ISR_handler *old_handler
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Warray-bounds"
-  /* Redirection table starts at the end of the vector table */
-  CPU_ISR_handler volatile  *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
-  CPU_ISR_handler current_handler = table [vector];
-  /* The current handler is now the old one */
-  if (old_handler != NULL) {
-    *old_handler = current_handler;
-  /* Write only if necessary to avoid writes to a maybe read-only memory */
-  if (current_handler != new_handler) {
-    table [vector] = new_handler;
-#pragma GCC diagnostic pop
 void _CPU_Initialize( void )
   /* Do nothing */
diff --git a/spec/build/cpukit/cpuarm.yml b/spec/build/cpukit/cpuarm.yml
index 5b140e46bb..88f84fd361 100644
--- a/spec/build/cpukit/cpuarm.yml
+++ b/spec/build/cpukit/cpuarm.yml
@@ -41,6 +41,7 @@ source:
 - cpukit/score/cpu/arm/arm_exc_interrupt.S
 - cpukit/score/cpu/arm/armv4-exception-default.S
 - cpukit/score/cpu/arm/armv4-sync-synchronize.c
+- cpukit/score/cpu/arm/armv4-isr-install-vector.c
 - cpukit/score/cpu/arm/armv7-thread-idle.c
 - cpukit/score/cpu/arm/armv7m-context-initialize.c
 - cpukit/score/cpu/arm/armv7m-context-restore.c
2.35.3
