[PATCH] improved error checking in ticks per timeslice
Joel Sherrill
joel at rtems.org
Tue Mar 19 01:12:49 UTC 2024
No. Just a lesson to remember -- Everyone along the path should have built
rtems with all tests enabled.
This is something that should never happen after the upcoming transition to
GitLab. It definitely shows we need to build at least one BSP with tests
enabled.
On Mon, Mar 18, 2024, 7:45 PM zack leung <zakthertemsdev at gmail.com> wrote:
> Do I need to do anything?
> On Mon, 18 Mar 2024 at 16:38, Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>> Sorry, I didn't realize I had tests turned off in my local build when I
>> checked this. The test is now gated behind NEEDS_CLOCK_DRIVER as well.
>> Kinsey
>> On Mon, Mar 18, 2024 at 4:15 AM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> This patch breaks the build:
>>> In file included from ../../../cpukit/include/rtems/confdefs.h:64,
>>> from
>>> ../../../testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c:215:
>>> ../../../cpukit/include/rtems/confdefs/clock.h:74:4: error: #error
>>> "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>>> 74 | #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than
>>> zero"
>>> from
>>> ../../../testsuites/rhealstone/rhmlatency/mlatency.c:158:
>>> zero"
>>> from
>>> ../../../testsuites/rhealstone/rhtaskswitch/taskswitch.c:122:
>>> zero"
>>> from
>>> ../../../testsuites/rhealstone/rhilatency/ilatency.c:29:
>>> zero"
>>> from
>>> ../../../testsuites/rhealstone/rhtaskpreempt/taskpreempt.c:120:
>>> zero"
>>> embedded brains GmbH & Co. KG
>>> Herr Sebastian HUBER
>>> Dornierstr. 4
>>> 82178 Puchheim
>>> Germany
>>> email: sebastian.huber at embedded-brains.de
>>> phone: +49-89-18 94 741 - 16
>>> fax: +49-89-18 94 741 - 08
>>> Registergericht: Amtsgericht München
>>> Registernummer: HRB 157899
>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>> Unsere Datenschutzerklärung finden Sie hier:
>>> https://embedded-brains.de/datenschutzerklaerung/
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240318/78d03236/attachment-0001.htm>
