[PATCH] bsps: Add BSP_FLUSH_KERNEL_CHAR_OUTPUT option
Tue Mar 19 02:16:43 UTC 2024
On 19/3/2024 3:49 am, Sebastian Huber wrote:
> Make the kernel I/O output character device flushing configurable.  The
> bsp_reset() function should reset the unit and do nothing else.
>  bsps/aarch64/xilinx-zynqmp/console/console.c  |  3 ++-
>  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  2 --
>  .../console/console-config.c                  |  3 ++-
>  bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |  2 --
>  bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c   |  3 ---
>  .../xilinx-zynqmp/console/console-config.c    |  2 +-
>  bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 --
>  bsps/arm/xilinx-zynqmp/start/bspreset.c       |  4 +---
>  bsps/include/bsp/bootcard.h                   |  5 +++++
>  bsps/shared/start/bspfatal-default.c          |  4 ++++
>  spec/build/bsps/bspopts.yml                   |  2 ++
>  spec/build/bsps/optflushkerncharout.yml       | 20 +++++++++++++++++++
>  12 files changed, 37 insertions(+), 15 deletions(-)
>  create mode 100644 spec/build/bsps/optflushkerncharout.yml
> diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
> index 9ce0b1da63..d1b2850952 100644
> --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> @@ -41,6 +41,7 @@
>  #include <rtems/termiostypes.h>
>  #include <bsp/aarch64-mmu.h>
> +#include <bsp/bootcard.h>
>  #include <bsp/fdt.h>
>  #include <bsp/irq.h>
> @@ -234,7 +235,7 @@ rtems_status_code console_initialize(
>    return RTEMS_SUCCESSFUL;
> -void zynqmp_debug_console_flush(void)
> +void bsp_flush_kernel_char_output(void)
>    zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
> diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> index 0ccca8b196..d36abde415 100644
> --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> @@ -86,8 +86,6 @@ BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
>  BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache( void );
> -void zynqmp_debug_console_flush(void);
>  uint32_t zynqmp_clock_i2c0(void);
>  uint32_t zynqmp_clock_i2c1(void);
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> index f52e008f2b..196b2dec58 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> @@ -35,6 +35,7 @@
>  #include <rtems/sysinit.h>
>  #include <dev/serial/zynq-uart.h>
> @@ -79,7 +80,7 @@ rtems_status_code console_initialize(
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> index e386bd4b26..060147967c 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> @@ -83,8 +83,6 @@ extern "C" {
>  BSP_START_TEXT_SECTION void zynqmp_setup_mpu_and_cache(void);
>  #ifdef __cplusplus
>  #endif /* __cplusplus */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> index eecb4da838..a894f55f6e 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> @@ -30,13 +30,10 @@
>   * POSSIBILITY OF SUCH DAMAGE.
> -#include <bsp.h>
>  void bsp_reset(void)
> -  zynqmp_debug_console_flush();
Why remove the call here?
>    while (true) {
>      /* Wait */
> diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
> index eadd7f11a2..360d193ba2 100644
> --- a/bsps/arm/xilinx-zynqmp/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
> @@ -81,7 +81,7 @@ rtems_status_code console_initialize(
> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
> index a08a5feee9..2785e4c2e0 100644
> --- a/bsps/arm/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
> @@ -79,8 +79,6 @@ extern "C" {
>  #ifdef __cplusplus
> diff --git a/bsps/arm/xilinx-zynqmp/start/bspreset.c b/bsps/arm/xilinx-zynqmp/start/bspreset.c
> index b43b19b05f..ed2f4da83a 100644
> --- a/bsps/arm/xilinx-zynqmp/start/bspreset.c
> +++ b/bsps/arm/xilinx-zynqmp/start/bspreset.c
> @@ -30,12 +30,10 @@
> -#include <bsp.h>
And here?
>    while (true) {
>      /* Wait */
> diff --git a/bsps/include/bsp/bootcard.h b/bsps/include/bsp/bootcard.h
> index 5f339d65f8..dfdc3ae7e0 100644
> --- a/bsps/include/bsp/bootcard.h
> +++ b/bsps/include/bsp/bootcard.h
> @@ -94,6 +94,11 @@ struct Per_CPU_Control;
>  void bsp_start_on_secondary_processor(struct Per_CPU_Control *cpu_self);
> + * @brief Flushes the kernel I/O output character device provided by the BSP.
> +void bsp_flush_kernel_char_output(void);
>  #ifdef __cplusplus
> diff --git a/bsps/shared/start/bspfatal-default.c b/bsps/shared/start/bspfatal-default.c
> index 557a0960fa..de3f414407 100644
> --- a/bsps/shared/start/bspfatal-default.c
> +++ b/bsps/shared/start/bspfatal-default.c
> @@ -184,6 +184,10 @@ void bsp_fatal_extension(
>      printk("\n");
>    #endif
> +  #if BSP_FLUSH_KERNEL_CHAR_OUTPUT
> +    bsp_flush_kernel_char_output();
> +  #endif
>     *  Check both conditions -- if you want to ask for reboot, then
>     *  you must have meant to reset the board.
> diff --git a/spec/build/bsps/bspopts.yml b/spec/build/bsps/bspopts.yml
> index 8128a56330..bdab4b72f3 100644
> --- a/spec/build/bsps/bspopts.yml
> +++ b/spec/build/bsps/bspopts.yml
> @@ -29,6 +29,8 @@ links:
>    uid: optincludes
>  - role: build-dependency
>    uid: optcflags
> +- role: build-dependency
> +  uid: optflushkerncharout
>    uid: optlinkflags
> diff --git a/spec/build/bsps/optflushkerncharout.yml b/spec/build/bsps/optflushkerncharout.yml
> new file mode 100644
> index 0000000000..c250229dd9
> --- /dev/null
> +++ b/spec/build/bsps/optflushkerncharout.yml
> @@ -0,0 +1,20 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2024 embedded brains GmbH & Co. KG
> +default:
> +- enabled-by: bsps/arm/xilinx-zynq
> +  value: 1
> +- enabled-by: true
> +  value: 0
> +description: |
> +  If defined to a non-zero value, flush the kernel I/O output character device
> +  provided by the BSP when the application exits.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: BSP_FLUSH_KERNEL_CHAR_OUTPUT
> +type: build
Is the flush enabled by default?
Why would you want to disable it?
