[PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Tue Mar 19 02:20:24 UTC 2024
On 19/3/2024 3:30 am, Sebastian Huber wrote:
>  spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml            | 2 +-
>  spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml  | 2 +-
>  spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml       | 2 +-
>  spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml | 2 +-
>  4 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> index ba70c44d7d..06795eb416 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> @@ -5,7 +5,7 @@ actions:
>  - env-append: null
>  build-type: option
>  copyrights:
> -- Copyright (C) 2023 Reflex Aerospace GmbH ( https://www.reflexaerospace.com/ )
> +- Copyright (C) 2023 Reflex Aerospace GmbH
Why this change?
>  default:
>  - enabled-by: true
>    value:
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
> index d08f048060..3fa210d8e7 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
> @@ -4,7 +4,7 @@ bsp: xilinx_zynqmp_mercuryxu5_rpu
>  build-type: bsp
>  cflags: []
>  copyrights:
>  cppflags: []
>  enabled-by: true
>  family: xilinx-zynqmp-rpu
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> index a3654f3f42..9c8a6d1cd6 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> @@ -38,7 +38,7 @@ content: |
>    _stack_end = bsp_section_stack_end;
>    __undef_stack = bsp_section_stack_begin;
>  copyrights:
>  enabled-by: true
>  install-path: ${BSP_LIBDIR}
>  links: []
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> index 09a3965906..d684f5a06d 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> @@ -4,7 +4,7 @@ actions:
>  - define-condition: null
>  build-type: option
>  copyrights:
>  default:
>  - enabled-by: true
>    value: true
