[PATCH 1/5] bsps: Use bsps/aarch64/xilinx-zynqmp
Tue Mar 19 02:21:04 UTC 2024
Does this patch series build at the per commit level?
On 19/3/2024 3:30 am, Sebastian Huber wrote:
>  spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml    | 6 +-----
>  spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml | 6 +-----
>  spec/build/cpukit/optsmp.yml                      | 6 +-----
>  3 files changed, 3 insertions(+), 15 deletions(-)
> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> index 5338538de0..44d2671eb6 100644
> --- a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> @@ -15,11 +15,7 @@ default:
>    - aarch64/xilinx_versal_aiedge
>    - aarch64/xilinx_versal_qemu
>    - aarch64/xilinx_versal_vck190
> -  - aarch64/xilinx_zynqmp_ilp32_qemu
> -  - aarch64/xilinx_zynqmp_ilp32_zu3eg
> -  - aarch64/xilinx_zynqmp_lp64_cfc400x
> -  - aarch64/xilinx_zynqmp_lp64_qemu
> -  - aarch64/xilinx_zynqmp_lp64_zu3eg
> +  - bsps/aarch64/xilinx-zynqmp
>    value: null
>  - enabled-by: true
>    value: 0x00000002
> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
> index fbc2dd9227..9b552c3f96 100644
> --- a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
>    value: null
>  - enabled-by: true
>    value: 0x00000001
> diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
> index 45d41299da..f78558d6eb 100644
> --- a/spec/build/cpukit/optsmp.yml
> +++ b/spec/build/cpukit/optsmp.yml
> @@ -13,11 +13,6 @@ default:
>  description: |
>    Enable the Symmetric Multiprocessing (SMP) support
>  enabled-by:
> -- aarch64/xilinx_zynqmp_ilp32_qemu
> -- aarch64/xilinx_zynqmp_ilp32_zu3eg
> -- aarch64/xilinx_zynqmp_lp64_cfc400x
> -- aarch64/xilinx_zynqmp_lp64_qemu
> -- aarch64/xilinx_zynqmp_lp64_zu3eg
>  - arm/altcycv_devkit
>  - arm/fvp_cortex_r52
>  - arm/imx7
> @@ -33,6 +28,7 @@ enabled-by:
>  - arm/xilinx_zynq_picozed
>  - arm/xilinx_zynq_pynq
>  - arm/xilinx_zynq_microzed
> +- bsps/aarch64/xilinx-zynqmp
>  - i386/pc386
>  - i386/pc486
>  - i386/pc586
