RTEMS 7 GDB Build Failure on FreeBSD 13
Tue Mar 19 02:22:14 UTC 2024
On 19/3/2024 1:27 am, Joel Sherrill wrote:
> I am going through the logs on the test sweep VMs to see why some builds are
> failing. This is due to gdb's requirement for GMP and MPFR. What's the
> recommended way to address this? Load native packages?
No, we need to add support to build them. We have to because other hosts like
MacOS do not have a standard package system.
