[PATCH v2] bsps: Add BSP_FLUSH_KERNEL_CHAR_OUTPUT BSP option
Tue Mar 19 15:03:10 UTC 2024
On 19.03.24 14:50, Kinsey Moore wrote:
> The xilinx-zynqmp-rpu bsp_reset() is modified, but not included in the
> spec file for the new option. Its family differs from the
> arm/xilinx-zynqmp BSP family with a -rpu suffix.
Yes, but this BSP is quite new. I would prefer to let it not flush
anything by default to carry out a reset.
> I'd be fine with this
> being enabled for the AArch64 BSPs as well, but I imagine that's better
> as a separate patch.
Why should it be enabled by default? The arm/xilinx-zynq and
arm/xilinx-zynqmp BSPs were the only ones doing an UART flush in the
general termination procedure. It probably was done to address a
specific use case (maybe test runs).
I don't really like the new bsp_flush_kernel_char_output() function.
Another approach could be an API change of
  * @ingroup RTEMSAPIKernelCharIO
  * @brief Polled character output functions shall have this type.
typedef void ( *BSP_output_char_function_type )( char );
to something like this
typedef int ( *BSP_output_char_function_type )( int action );
If action in {0, ..., 255}, then print out the character. If 0x100 is
set, then flush the output device. If 0x200 is set, then do Y... The
return value could be used to give a status indication.
This could then be use for example by test runs, to flush the test
output after the end of the test.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
