[PATCH] Do not define CONFIGURE_TICKS_PER_TIMESLICE to 0
Wed Mar 20 14:22:55 UTC 2024
On 20.03.24 15:14, Joel Sherrill wrote:
> This is generally ok but it contradicts the documented behavior
> for CONFIGURE_TICKS_PER_TIMESLICE which states "The value of the
> configuration option shall be greater than or equal to zero."
This is the problem of the referenced ticket:
https://devel.rtems.org/ticket/4986
> If zero is to be an error, then that needs to change.
This is what the patch does.
> Further, this series of changes has made me realize that
> CONFIGURE_TICKS_PER_TIMESLICE and CONFIGURE_MICROSECONDS_PER_TICK should
> not be defined if the application has not defined
> CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER. Currently the documentation
> just says it has no effect.
This is a different topic. I would like to first fix the undefined
behaviour if some uses:
#define CONFIGURE_TICKS_PER_TIMESLICE 0
> Also the formatting of the text in the description is inconsistent.
> Could a ref be used for all of this?
> The application shall define exactly one of the following configuration
> options
> * :ref:`CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`,
> * ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER``, or
> * :ref:`CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`,
Sorry, were is this in the patch?
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
