[PATCH] bsps: Avoid unused argument in clock interrupt
Wed Mar 20 14:29:33 UTC 2024
Pass the parameter of the clock interrupt handler to
Clock_driver_support_at_tick() and Clock_driver_timecounter_tick().  This makes
it possible to use the interrupt handler argument in clock drivers.
Use the interrupt handler provided by Clock_driver_support_install_isr() to
avoid local delarations of Clock_isr().
Update #4862.
 bsps/arm/beagle/clock/clock.c                 |  2 +-
 bsps/arm/csb336/clock/clockdrv.c              |  2 +-
 bsps/arm/csb337/clock/clock.c                 |  2 +-
 bsps/arm/edb7312/clock/clockdrv.c             |  6 +--
 bsps/arm/gumstix/clock/clock.c                |  2 +-
 bsps/arm/raspberrypi/clock/clockdrv.c         | 27 +++++---------
 bsps/arm/rtl22xx/clock/clockdrv.c             |  2 +-
 bsps/arm/shared/clock/clock-a9mpcore.c        | 28 ++++++--------
 bsps/arm/shared/clock/clock-nxp-lpc.c         | 17 ++++-----
 bsps/arm/smdk2410/clock/clockdrv.c            |  2 +-
 bsps/arm/tms570/clock/clock.c                 | 20 +++++-----
 bsps/i386/pc386/clock/ckinit.c                |  2 +-
 bsps/lm32/shared/clock/ckinit.c               |  2 +-
 bsps/lm32/shared/milkymist_clock/ckinit.c     |  2 +-
 bsps/m68k/av5282/clock/clock.c                |  2 +-
 bsps/m68k/gen68360/clock/clock.c              |  2 +-
 bsps/m68k/genmcf548x/clock/clock.c            |  2 +-
 bsps/m68k/mcf52235/clock/clock.c              |  2 +-
 bsps/m68k/mcf5225x/clock/clock.c              |  2 +-
 bsps/m68k/mcf5235/clock/clock.c               |  2 +-
 bsps/m68k/mcf5329/clock/clock.c               |  2 +-
 bsps/m68k/mrm332/btimer/btimer.c              |  2 -
 bsps/m68k/uC5282/clock/clock.c                |  2 +-
 bsps/microblaze/microblaze_fpga/clock/clock.c |  8 ++--
 bsps/mips/csb350/clock/clockdrv.c             |  4 +-
 bsps/mips/rbtx4925/clock/clockdrv.c           |  2 +-
 bsps/mips/rbtx4938/clock/clockdrv.c           |  2 +-
 bsps/mips/shared/clock/clockdrv.c             |  2 +-
 bsps/nios2/nios2_iss/clock/clock.c            |  2 +-
 bsps/or1k/generic_or1k/clock/clockdrv.c       |  2 +-
 bsps/powerpc/mpc55xxevb/clock/clock-config.c  | 24 ++++++------
 bsps/powerpc/qoriq/clock/clock-config.c       | 14 +++----
 bsps/riscv/griscv/clock/clockdrv.c            |  2 +-
 bsps/riscv/riscv/clock/clockdrv.c             | 13 +++----
 bsps/shared/dev/clock/arm-generic-timer.c     | 19 ++++------
 bsps/shared/dev/clock/clockimpl.h             | 37 +++++++++----------
 bsps/shared/dev/clock/xil-ttc.c               | 32 ++++++----------
 bsps/shared/grlib/btimer/tlib_ckinit.c        |  4 +-
 bsps/sparc/erc32/clock/ckinit.c               |  8 ++--
 bsps/sparc/leon2/clock/ckinit.c               |  2 +-
 bsps/sparc/leon3/clock/ckinit.c               |  2 +-
 bsps/sparc64/shared/clock/ckinit.c            |  2 +-
 42 files changed, 137 insertions(+), 178 deletions(-)
diff --git a/bsps/arm/beagle/clock/clock.c b/bsps/arm/beagle/clock/clock.c
index d42b051c98..a32dde86bf 100644
--- a/bsps/arm/beagle/clock/clock.c
+++ b/bsps/arm/beagle/clock/clock.c
@@ -290,7 +290,7 @@ static void beagle_clock_handler_install(rtems_interrupt_handler isr)
   clock_isr = isr;
-#define Clock_driver_support_at_tick() beagle_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) beagle_clock_at_tick()
 #define Clock_driver_support_initialize_hardware() beagle_clock_initialize()
 #define Clock_driver_support_install_isr(isr) \
   beagle_clock_handler_install(isr)
diff --git a/bsps/arm/csb336/clock/clockdrv.c b/bsps/arm/csb336/clock/clockdrv.c
index 58f98d87be..6af507a877 100644
--- a/bsps/arm/csb336/clock/clockdrv.c
+++ b/bsps/arm/csb336/clock/clockdrv.c
@@ -38,7 +38,7 @@ rtems_irq_connect_data clock_isr_data = {
  *    - clear the interrupt bit?
  *    - restart the timer?
-#define Clock_driver_support_at_tick()               \
+#define Clock_driver_support_at_tick(arg)            \
   do {                                               \
     uint32_t reg;                                    \
diff --git a/bsps/arm/csb337/clock/clock.c b/bsps/arm/csb337/clock/clock.c
index 69a3dafd81..ee05387baa 100644
--- a/bsps/arm/csb337/clock/clock.c
+++ b/bsps/arm/csb337/clock/clock.c
@@ -94,7 +94,7 @@ static void Clock_driver_support_initialize_hardware(void)
   ST_REG(ST_PIMR) = value;
   do { \
     uint32_t st_str; \
diff --git a/bsps/arm/edb7312/clock/clockdrv.c b/bsps/arm/edb7312/clock/clockdrv.c
index 8c7cc4f26a..79289366da 100644
--- a/bsps/arm/edb7312/clock/clockdrv.c
+++ b/bsps/arm/edb7312/clock/clockdrv.c
@@ -18,9 +18,7 @@
   #define CLOCK_DRIVER_USE_FAST_IDLE 1
 #endif
-void Clock_isr(void * arg);
   do {                                                \
     *EP7312_TC1EOI = 0xffffffff;                      \
   } while(0)
@@ -32,7 +30,7 @@ void Clock_isr(void * arg);
         BSP_TC1OI,                                     \
         "Clock",                                       \
         RTEMS_INTERRUPT_UNIQUE,                        \
-        Clock_isr,                                     \
+        _new,                                          \
         NULL                                           \
     assert(status == RTEMS_SUCCESSFUL);                \
diff --git a/bsps/arm/gumstix/clock/clock.c b/bsps/arm/gumstix/clock/clock.c
index c844f50a37..1e8f1fcb3f 100644
--- a/bsps/arm/gumstix/clock/clock.c
+++ b/bsps/arm/gumstix/clock/clock.c
@@ -99,7 +99,7 @@ static void Clock_driver_support_initialize_hardware(void)
 #endif
   do { \
     /* read the status to clear the int */ \
     XSCALE_OS_TIMER_TSR = 0x1; \
diff --git a/bsps/arm/raspberrypi/clock/clockdrv.c b/bsps/arm/raspberrypi/clock/clockdrv.c
index 8d220d51ba..9fc2a46af8 100644
--- a/bsps/arm/raspberrypi/clock/clockdrv.c
+++ b/bsps/arm/raspberrypi/clock/clockdrv.c
@@ -54,27 +54,18 @@ static void raspberrypi_clock_at_tick(void)
 static void raspberrypi_clock_handler_install_isr(
-  rtems_isr_entry clock_isr
+  rtems_interrupt_handler clock_isr
   rtems_status_code sc = RTEMS_SUCCESSFUL;
-  if (clock_isr != NULL) {
-    sc = rtems_interrupt_handler_install(
-      BCM2835_IRQ_ID_GPU_TIMER_M3,
-      "Clock",
-      RTEMS_INTERRUPT_UNIQUE,
-      (rtems_interrupt_handler) clock_isr,
-      NULL
-  } else {
-    /* Remove interrupt handler */
-    sc = rtems_interrupt_handler_remove(
-      (rtems_interrupt_handler) Clock_isr,
-      NULL
+  sc = rtems_interrupt_handler_install(
+    BCM2835_IRQ_ID_GPU_TIMER_M3,
+    "Clock",
+    RTEMS_INTERRUPT_UNIQUE,
+    clock_isr,
+    NULL
   if ( sc != RTEMS_SUCCESSFUL ) {
     rtems_fatal_error_occurred(0xdeadbeef);
@@ -94,7 +85,7 @@ static void raspberrypi_clock_initialize_hardware(void)
   rtems_timecounter_install(&raspberrypi_tc);
-#define Clock_driver_support_at_tick() raspberrypi_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) raspberrypi_clock_at_tick()
 #define Clock_driver_support_initialize_hardware() raspberrypi_clock_initialize_hardware()
diff --git a/bsps/arm/rtl22xx/clock/clockdrv.c b/bsps/arm/rtl22xx/clock/clockdrv.c
index 0e8fa274a7..53b6a763ee 100644
--- a/bsps/arm/rtl22xx/clock/clockdrv.c
+++ b/bsps/arm/rtl22xx/clock/clockdrv.c
@@ -157,7 +157,7 @@ static int clock_isr_is_on(const rtems_irq_connect_data *irq)
   return T0IR & 0x01;  /* MR0 mask */
-#define Clock_driver_timecounter_tick() lpc22xx_tc_tick()
+#define Clock_driver_timecounter_tick(arg) lpc22xx_tc_tick()
 /* Make sure to include this, and only at the end of the file */
 #include "../../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/arm/shared/clock/clock-a9mpcore.c b/bsps/arm/shared/clock/clock-a9mpcore.c
index 9e0b3418d4..c393933c81 100644
--- a/bsps/arm/shared/clock/clock-a9mpcore.c
+++ b/bsps/arm/shared/clock/clock-a9mpcore.c
@@ -47,33 +47,29 @@
 static struct timecounter a9mpcore_tc;
-/* This is defined in dev/clock/clockimpl.h */
-void Clock_isr(void *arg);
 __attribute__ ((weak)) uint32_t a9mpcore_clock_periphclk(void)
   /* default to the BSP option. */
   return BSP_ARM_A9MPCORE_PERIPHCLK;
-static void a9mpcore_clock_at_tick(void)
+static void a9mpcore_clock_at_tick(volatile a9mpcore_gt *gt)
-  volatile a9mpcore_gt *gt = A9MPCORE_GT;
   gt->irqst = A9MPCORE_GT_IRQST_EFLG;
-static rtems_interrupt_entry a9mpcore_clock_interrupt_entry =
-  RTEMS_INTERRUPT_ENTRY_INITIALIZER(
-    NULL,
-    "Clock"
+static rtems_interrupt_entry a9mpcore_clock_interrupt_entry;
-static void a9mpcore_clock_handler_install(void)
+static void a9mpcore_clock_handler_install(rtems_interrupt_handler handler)
   rtems_status_code sc;
+  rtems_interrupt_entry_initialize(
+    &a9mpcore_clock_interrupt_entry,
+    handler,
+    RTEMS_DEVOLATILE(a9mpcore_gt *, A9MPCORE_GT),
+    "Clock"
   sc = rtems_interrupt_entry_install(
     A9MPCORE_IRQ_GT,
@@ -193,14 +189,14 @@ CPU_Counter_ticks _CPU_Counter_read(void)
   return gt->cntrlower;
-  a9mpcore_clock_at_tick()
+  a9mpcore_clock_at_tick(arg)
 #define Clock_driver_support_initialize_hardware() \
   a9mpcore_clock_initialize()
-  a9mpcore_clock_handler_install()
+  a9mpcore_clock_handler_install(isr)
 /* Include shared source clock driver code */
 #include "../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/arm/shared/clock/clock-nxp-lpc.c b/bsps/arm/shared/clock/clock-nxp-lpc.c
index 86ece94b0e..77d6d423a2 100644
--- a/bsps/arm/shared/clock/clock-nxp-lpc.c
+++ b/bsps/arm/shared/clock/clock-nxp-lpc.c
@@ -41,9 +41,6 @@
 #ifdef ARM_MULTILIB_ARCH_V4
-/* This is defined in ../../../shared/dev/clock/clockimpl.h */
-void Clock_isr(rtems_irq_hdl_param arg);
 static volatile lpc_timer *const lpc_clock =
   (volatile lpc_timer *) LPC_CLOCK_TIMER_BASE;
@@ -57,12 +54,12 @@ static uint32_t lpc_clock_tc_get_timecount(struct timecounter *tc)
   return lpc_timecounter->tc;
-static void lpc_clock_at_tick(void)
+static void lpc_clock_at_tick(volatile lpc_timer *regs)
-  lpc_clock->ir = LPC_TIMER_IR_MR0;
+  regs->ir = LPC_TIMER_IR_MR0;
-static void lpc_clock_handler_install(void)
+static void lpc_clock_handler_install(rtems_interrupt_handler handler)
@@ -70,8 +67,8 @@ static void lpc_clock_handler_install(void)
     LPC_CLOCK_INTERRUPT,
     "Clock",
-    NULL
+    handler,
+    RTEMS_DEVOLATILE(lpc_timer *, lpc_clock)
   if (sc != RTEMS_SUCCESSFUL) {
@@ -118,10 +115,10 @@ static void lpc_clock_initialize(void)
   rtems_timecounter_install(&lpc_clock_tc);
-#define Clock_driver_support_at_tick() lpc_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) lpc_clock_at_tick(arg)
 #define Clock_driver_support_initialize_hardware() lpc_clock_initialize()
-  lpc_clock_handler_install()
+  lpc_clock_handler_install(isr)
diff --git a/bsps/arm/smdk2410/clock/clockdrv.c b/bsps/arm/smdk2410/clock/clockdrv.c
index 6e32b7daed..0d0a0fd006 100644
--- a/bsps/arm/smdk2410/clock/clockdrv.c
+++ b/bsps/arm/smdk2410/clock/clockdrv.c
@@ -32,7 +32,7 @@ rtems_irq_connect_data clock_isr_data = {
   do {                                                \
         ClearPending(BIT_TIMER4);                     \
   } while(0)
diff --git a/bsps/arm/tms570/clock/clock.c b/bsps/arm/tms570/clock/clock.c
index 5e5965a680..2e71440857 100644
--- a/bsps/arm/tms570/clock/clock.c
+++ b/bsps/arm/tms570/clock/clock.c
@@ -144,9 +144,9 @@ static void tms570_clock_driver_support_initialize_hardware( void )
  * @retval Void
-static void tms570_clock_driver_support_at_tick( void )
+static void tms570_clock_driver_support_at_tick(volatile tms570_rti_t *rti)
-  TMS570_RTI.INTFLAG = TMS570_RTI_INTFLAG_INT0;
+  rti->INTFLAG = TMS570_RTI_INTFLAG_INT0;
@@ -158,7 +158,7 @@ static void tms570_clock_driver_support_at_tick( void )
  * @retval Void
 static void tms570_clock_driver_support_install_isr(
-  rtems_isr_entry Clock_isr
+  rtems_interrupt_handler handler
@@ -167,8 +167,8 @@ static void tms570_clock_driver_support_install_isr(
     TMS570_IRQ_TIMER_0,
     "Clock",
-    NULL
+    handler,
+    RTEMS_DEVOLATILE(tms570_rti_t *, &TMS570_RTI)
@@ -177,14 +177,12 @@ static void tms570_clock_driver_support_install_isr(
 #define Clock_driver_support_initialize_hardware \
-#define Clock_driver_support_at_tick \
-                        tms570_clock_driver_support_at_tick
+                        tms570_clock_driver_support_at_tick(arg)
-#define Clock_driver_support_install_isr(Clock_isr) \
-              tms570_clock_driver_support_install_isr( Clock_isr )
-void Clock_isr(void *arg); /* to supress warning */
+#define Clock_driver_support_install_isr(handler) \
+              tms570_clock_driver_support_install_isr(handler)
diff --git a/bsps/i386/pc386/clock/ckinit.c b/bsps/i386/pc386/clock/ckinit.c
index 3fdb0d5afe..d0519ee061 100644
--- a/bsps/i386/pc386/clock/ckinit.c
+++ b/bsps/i386/pc386/clock/ckinit.c
@@ -87,7 +87,7 @@ extern volatile uint32_t Clock_driver_ticks;
 #ifdef RTEMS_SMP
   do {                                                              \
     Processor_mask targets;                                         \
     _Processor_mask_Assign(&targets, _SMP_Get_online_processors()); \
diff --git a/bsps/lm32/shared/clock/ckinit.c b/bsps/lm32/shared/clock/ckinit.c
index f4bd395eb6..84220b2606 100644
--- a/bsps/lm32/shared/clock/ckinit.c
+++ b/bsps/lm32/shared/clock/ckinit.c
@@ -59,7 +59,7 @@ static inline void clockwrite(unsigned int reg, int value)
 #define CLOCK_VECTOR    ( TIMER0_IRQ )
 #define CLOCK_IRQMASK   ( 1 << CLOCK_VECTOR )
   do { \
     /* Clear overflow flag */ \
     clockwrite(LM32_CLOCK_SR, 0); \
diff --git a/bsps/lm32/shared/milkymist_clock/ckinit.c b/bsps/lm32/shared/milkymist_clock/ckinit.c
index b10eb858c7..15b459eb74 100644
--- a/bsps/lm32/shared/milkymist_clock/ckinit.c
+++ b/bsps/lm32/shared/milkymist_clock/ckinit.c
@@ -21,7 +21,7 @@
 #endif
   do { \
     lm32_interrupt_ack(1 << MM_IRQ_TIMER0); \
   } while (0)
diff --git a/bsps/m68k/av5282/clock/clock.c b/bsps/m68k/av5282/clock/clock.c
index b1e169b4c9..1c4a6a0ba7 100644
--- a/bsps/m68k/av5282/clock/clock.c
+++ b/bsps/m68k/av5282/clock/clock.c
@@ -14,7 +14,7 @@
  * Periodic interval timer interrupt handler
     do {                                           \
         MCF5282_PIT3_PCSR |= MCF5282_PIT_PCSR_PIF; \
     } while (0)                                    \
diff --git a/bsps/m68k/gen68360/clock/clock.c b/bsps/m68k/gen68360/clock/clock.c
index 966b20dae4..07da6a034d 100644
--- a/bsps/m68k/gen68360/clock/clock.c
+++ b/bsps/m68k/gen68360/clock/clock.c
@@ -33,7 +33,7 @@ static unsigned long nsec;
  *        Application code can override this by
  *        setting M360DefaultWatchdogFeeder to zero.
     do {                                   \
         nsec += pit_nsec_per_tick;         \
         if (nsec >= rtems_nsec_per_tick)   \
diff --git a/bsps/m68k/genmcf548x/clock/clock.c b/bsps/m68k/genmcf548x/clock/clock.c
index 3bf08a06f9..fbb2c8592f 100644
--- a/bsps/m68k/genmcf548x/clock/clock.c
+++ b/bsps/m68k/genmcf548x/clock/clock.c
@@ -62,7 +62,7 @@
     do {                                           \
         MCF548X_SLT_SSR0 = MCF548X_SLT_SSR_ST;     \
     } while (0)                                    \
diff --git a/bsps/m68k/mcf52235/clock/clock.c b/bsps/m68k/mcf52235/clock/clock.c
index d5e1817536..eb28e5d328 100644
--- a/bsps/m68k/mcf52235/clock/clock.c
+++ b/bsps/m68k/mcf52235/clock/clock.c
@@ -93,6 +93,6 @@ static void Clock_driver_support_initialize_hardware(void)
-#define Clock_driver_timecounter_tick() mcf52235_tc_tick()
+#define Clock_driver_timecounter_tick(arg) mcf52235_tc_tick()
diff --git a/bsps/m68k/mcf5225x/clock/clock.c b/bsps/m68k/mcf5225x/clock/clock.c
index 9a9c7cabe4..3cd76aa17a 100644
--- a/bsps/m68k/mcf5225x/clock/clock.c
+++ b/bsps/m68k/mcf5225x/clock/clock.c
-#define Clock_driver_timecounter_tick() mcf5225x_tc_tick()
+#define Clock_driver_timecounter_tick(arg) mcf5225x_tc_tick()
diff --git a/bsps/m68k/mcf5235/clock/clock.c b/bsps/m68k/mcf5235/clock/clock.c
index 8b848de006..2aebd8385c 100644
--- a/bsps/m68k/mcf5235/clock/clock.c
+++ b/bsps/m68k/mcf5235/clock/clock.c
@@ -14,7 +14,7 @@
     do {                                           \
         MCF5235_PIT_PCSR3 |= MCF5235_PIT_PCSR_PIF; \
     } while (0)                                    \
diff --git a/bsps/m68k/mcf5329/clock/clock.c b/bsps/m68k/mcf5329/clock/clock.c
index 6ad46fe5a1..2833111572 100644
--- a/bsps/m68k/mcf5329/clock/clock.c
+++ b/bsps/m68k/mcf5329/clock/clock.c
@@ -92,6 +92,6 @@ static void Clock_driver_support_initialize_hardware(void)
-#define Clock_driver_timecounter_tick() mcf5329_tc_tick()
+#define Clock_driver_timecounter_tick(arg) mcf5329_tc_tick()
diff --git a/bsps/m68k/mrm332/btimer/btimer.c b/bsps/m68k/mrm332/btimer/btimer.c
index 4aa3cd013e..138884dd32 100644
--- a/bsps/m68k/mrm332/btimer/btimer.c
+++ b/bsps/m68k/mrm332/btimer/btimer.c
@@ -31,8 +31,6 @@
 bool benchmark_timer_find_average_overhead;
-extern rtems_isr Clock_isr(void);
 void benchmark_timer_initialize( void )
diff --git a/bsps/m68k/uC5282/clock/clock.c b/bsps/m68k/uC5282/clock/clock.c
index 59d67af296..f7bed25b8b 100644
--- a/bsps/m68k/uC5282/clock/clock.c
+++ b/bsps/m68k/uC5282/clock/clock.c
@@ -150,6 +150,6 @@ int bsp_cpu_load_percentage(void)
            0;
-#define Clock_driver_timecounter_tick() uC5282_tc_tick()
+#define Clock_driver_timecounter_tick(arg) uC5282_tc_tick()
diff --git a/bsps/microblaze/microblaze_fpga/clock/clock.c b/bsps/microblaze/microblaze_fpga/clock/clock.c
index 19e960022b..16acbaeebb 100644
--- a/bsps/microblaze/microblaze_fpga/clock/clock.c
+++ b/bsps/microblaze/microblaze_fpga/clock/clock.c
@@ -118,10 +118,10 @@ static void microblaze_clock_at_tick( rtems_timecounter_simple *tc )
   mblaze_timer->tcsr0 |= MICROBLAZE_TIMER_TCSR0_T0INT;
-static void microblaze_tc_tick( void )
+static void microblaze_tc_tick( rtems_timecounter_simple *tc )
   rtems_timecounter_simple_downcounter_tick(
-    &mblaze_tc,
+    tc,
     microblaze_tc_get,
@@ -142,7 +142,7 @@ static void microblaze_clock_handler_install( rtems_interrupt_handler isr )
     "Clock",
     isr,
-    NULL
+    &mblaze_tc
@@ -153,7 +153,7 @@ static void microblaze_clock_handler_install( rtems_interrupt_handler isr )
 #define Clock_driver_support_initialize_hardware() microblaze_clock_initialize()
 #define Clock_driver_support_install_isr( isr ) \
   microblaze_clock_handler_install( isr )
-#define Clock_driver_timecounter_tick() microblaze_tc_tick()
+#define Clock_driver_timecounter_tick(arg) microblaze_tc_tick(arg)
diff --git a/bsps/mips/csb350/clock/clockdrv.c b/bsps/mips/csb350/clock/clockdrv.c
index 3816bc1ef3..beb3e35221 100644
--- a/bsps/mips/csb350/clock/clockdrv.c
+++ b/bsps/mips/csb350/clock/clockdrv.c
@@ -27,8 +27,8 @@ void au1x00_clock_init(void);
 #define CLOCK_VECTOR AU1X00_IRQ_TOY_MATCH2
-  do {                                                        \
+  do { \
     while (AU1X00_SYS_CNTCTRL(AU1X00_SYS_ADDR) & AU1X00_SYS_CNTCTRL_TM0); \
     last_match = AU1X00_SYS_TOYREAD(AU1X00_SYS_ADDR); \
     AU1X00_SYS_TOYMATCH2(AU1X00_SYS_ADDR) = last_match + tick_interval; \
diff --git a/bsps/mips/rbtx4925/clock/clockdrv.c b/bsps/mips/rbtx4925/clock/clockdrv.c
index 7cbf41b963..0a71c8647f 100644
--- a/bsps/mips/rbtx4925/clock/clockdrv.c
+++ b/bsps/mips/rbtx4925/clock/clockdrv.c
@@ -61,7 +61,7 @@
   rtems_interrupt_handler_install( CLOCK_VECTOR, "clock", 0, _new, NULL )
   do { \
 	uint32_t interrupt_flag; \
   	do { \
diff --git a/bsps/mips/rbtx4938/clock/clockdrv.c b/bsps/mips/rbtx4938/clock/clockdrv.c
index 2515298d67..5d00979649 100644
--- a/bsps/mips/rbtx4938/clock/clockdrv.c
+++ b/bsps/mips/rbtx4938/clock/clockdrv.c
@@ -89,7 +89,7 @@ void new_brk_esr(void)
   } while(0)
   do { \
   	do { \
diff --git a/bsps/mips/shared/clock/clockdrv.c b/bsps/mips/shared/clock/clockdrv.c
index ed420fb5eb..73c76e42d8 100644
--- a/bsps/mips/shared/clock/clockdrv.c
+++ b/bsps/mips/shared/clock/clockdrv.c
@@ -44,7 +44,7 @@ extern uint32_t bsp_clicks_per_microsecond;
 static uint32_t mips_timer_rate = 0;
 /* refresh the internal CPU timer */
   mips_set_timer( mips_timer_rate );
 #define Clock_driver_support_install_isr( _new ) \
diff --git a/bsps/nios2/nios2_iss/clock/clock.c b/bsps/nios2/nios2_iss/clock/clock.c
index 5b9b6bb1b5..e22cfcc686 100644
--- a/bsps/nios2/nios2_iss/clock/clock.c
+++ b/bsps/nios2/nios2_iss/clock/clock.c
@@ -12,7 +12,7 @@
   do { CLOCK_REGS->status = 0; } while(0)
diff --git a/bsps/or1k/generic_or1k/clock/clockdrv.c b/bsps/or1k/generic_or1k/clock/clockdrv.c
index 44f220e057..4409b49ed4 100644
--- a/bsps/or1k/generic_or1k/clock/clockdrv.c
+++ b/bsps/or1k/generic_or1k/clock/clockdrv.c
@@ -108,7 +108,7 @@ static void generic_or1k_clock_initialize(void)
   rtems_timecounter_install(&or1ksim_tc);
-#define Clock_driver_support_at_tick() generic_or1k_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) generic_or1k_clock_at_tick()
 #define Clock_driver_support_initialize_hardware() generic_or1k_clock_initialize()
diff --git a/bsps/powerpc/mpc55xxevb/clock/clock-config.c b/bsps/powerpc/mpc55xxevb/clock/clock-config.c
index 9a666fc85a..d48367ae1e 100644
--- a/bsps/powerpc/mpc55xxevb/clock/clock-config.c
+++ b/bsps/powerpc/mpc55xxevb/clock/clock-config.c
@@ -41,8 +41,6 @@
 #include <rtems/timecounter.h>
 static rtems_timecounter_simple mpc55xx_tc;
 #if defined(MPC55XX_CLOCK_EMIOS_CHANNEL)
@@ -75,16 +73,16 @@ static void mpc55xx_tc_at_tick(rtems_timecounter_simple *tc)
   EMIOS.CH [MPC55XX_CLOCK_EMIOS_CHANNEL].CSR.R = csr.R;
-static void mpc55xx_tc_tick(void)
+static void mpc55xx_tc_tick(rtems_timecounter_simple *tc)
   rtems_timecounter_simple_upcounter_tick(
-    &mpc55xx_tc,
+    tc,
     mpc55xx_tc_get,
     mpc55xx_tc_at_tick
-static void mpc55xx_clock_handler_install(rtems_isr_entry isr)
+static void mpc55xx_clock_handler_install(rtems_interrupt_handler handler)
@@ -93,8 +91,8 @@ static void mpc55xx_clock_handler_install(rtems_isr_entry isr)
     "clock",
     MPC55XX_INTC_MIN_PRIORITY,
-    (rtems_interrupt_handler) isr,
-    NULL
+    handler,
+    &mpc55xx_tc
     bsp_fatal(MPC55XX_FATAL_CLOCK_EMIOS_IRQ_INSTALL);
@@ -190,16 +188,16 @@ static void mpc55xx_tc_at_tick(rtems_timecounter_simple *tc)
   channel->TFLG.R = tflg.R;
-    &mpc55xx_tc,
+    tc,
     mpc55xx_tc_get,
     mpc55xx_tc_at_tick
@@ -208,8 +206,8 @@ static void mpc55xx_clock_handler_install(rtems_isr_entry isr)
     "clock",
-    NULL
+    handler,
+    &mpc55xx_tc
     bsp_fatal(MPC55XX_FATAL_CLOCK_PIT_IRQ_INSTALL);
@@ -240,7 +238,7 @@ static void mpc55xx_clock_initialize(void)
 #endif
-#define Clock_driver_timecounter_tick() mpc55xx_tc_tick()
+#define Clock_driver_timecounter_tick(arg) mpc55xx_tc_tick(arg)
   mpc55xx_clock_initialize()
diff --git a/bsps/powerpc/qoriq/clock/clock-config.c b/bsps/powerpc/qoriq/clock/clock-config.c
index 746e9975ea..8ecc19ef0d 100644
--- a/bsps/powerpc/qoriq/clock/clock-config.c
+++ b/bsps/powerpc/qoriq/clock/clock-config.c
@@ -42,15 +42,15 @@
 #include <bsp/qoriq.h>
 #include <bsp/irq.h>
-static rtems_isr Clock_isr(void *arg);
 static struct timecounter qoriq_clock_tc;
 #ifdef QORIQ_IS_HYPERVISOR_GUEST
 #define CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
+/* This is defined in dev/clock/clockimpl.h */
+static rtems_isr Clock_isr(void *arg);
 void qoriq_decrementer_dispatch(void)
   PPC_SET_SPECIAL_PURPOSE_REGISTER(BOOKE_TSR, BOOKE_TSR_DIS);
@@ -102,7 +102,7 @@ static volatile qoriq_pic_global_timer *const qoriq_timecounter =
 static rtems_interrupt_entry qoriq_clock_entry;
-static void qoriq_clock_handler_install(void)
+static void qoriq_clock_handler_install(rtems_interrupt_handler handler)
@@ -126,7 +126,7 @@ static void qoriq_clock_handler_install(void)
     &qoriq_clock_entry,
-    Clock_isr,
+    handler,
     NULL,
     "Clock"
@@ -164,8 +164,8 @@ static void qoriq_clock_initialize(void)
   rtems_timecounter_install(&qoriq_clock_tc);
-#define Clock_driver_support_install_isr(clock_isr) \
-  qoriq_clock_handler_install()
+#define Clock_driver_support_install_isr(isr) \
+  qoriq_clock_handler_install(isr)
 #define Clock_driver_support_set_interrupt_affinity(online_processors) \
   bsp_interrupt_set_affinity(CLOCK_INTERRUPT, online_processors)
diff --git a/bsps/riscv/griscv/clock/clockdrv.c b/bsps/riscv/griscv/clock/clockdrv.c
index ab82751e69..817cb331b6 100644
--- a/bsps/riscv/griscv/clock/clockdrv.c
+++ b/bsps/riscv/griscv/clock/clockdrv.c
@@ -220,7 +220,7 @@ CPU_Counter_ticks _CPU_Counter_read( void )
   grlib_clock_initialize()
-#define Clock_driver_timecounter_tick() grlib_tc_do_tick()
+#define Clock_driver_timecounter_tick(arg) grlib_tc_do_tick()
diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
index ebbc9d77d9..d2f8f5da54 100644
--- a/bsps/riscv/riscv/clock/clockdrv.c
+++ b/bsps/riscv/riscv/clock/clockdrv.c
@@ -47,9 +47,6 @@
 #include <libfdt.h>
 typedef struct {
   struct timecounter base;
   volatile RISCV_CLINT_regs *clint;
@@ -105,7 +102,7 @@ static void riscv_clock_at_tick(riscv_timecounter *tc)
   riscv_clock_write_mtimecmp(mtimecmp, value);
-static void riscv_clock_handler_install(void)
+static void riscv_clock_handler_install(rtems_interrupt_handler handler)
@@ -113,8 +110,8 @@ static void riscv_clock_handler_install(void)
     RISCV_INTERRUPT_VECTOR_TIMER,
     "Clock",
-    NULL
+    handler,
+    &riscv_clock_tc
     bsp_fatal(RISCV_FATAL_CLOCK_IRQ_INSTALL);
@@ -242,11 +239,11 @@ RTEMS_SYSINIT_ITEM(
   RTEMS_SYSINIT_ORDER_FIRST
-#define Clock_driver_support_at_tick() riscv_clock_at_tick(&riscv_clock_tc)
+#define Clock_driver_support_at_tick(arg) riscv_clock_at_tick(arg)
 #define Clock_driver_support_initialize_hardware() riscv_clock_initialize()
-  riscv_clock_handler_install()
+  riscv_clock_handler_install(isr)
diff --git a/bsps/shared/dev/clock/arm-generic-timer.c b/bsps/shared/dev/clock/arm-generic-timer.c
index 1188800170..ba159f6833 100644
--- a/bsps/shared/dev/clock/arm-generic-timer.c
+++ b/bsps/shared/dev/clock/arm-generic-timer.c
@@ -54,15 +54,12 @@ typedef struct {
 static arm_gt_clock_context arm_gt_clock_instance;
-static void arm_gt_clock_at_tick(void)
+static void arm_gt_clock_at_tick(arm_gt_clock_context *ctx)
   uint64_t cval;
   uint32_t interval;
-  interval = arm_gt_clock_instance.interval;
+  interval = ctx->interval;
   cval = arm_gt_clock_get_compare_value();
   cval += interval;
   arm_gt_clock_set_compare_value(cval);
@@ -71,7 +68,7 @@ static void arm_gt_clock_at_tick(void)
 #endif /* ARM_GENERIC_TIMER_UNMASK_AT_TICK */
-static void arm_gt_clock_handler_install(void)
+static void arm_gt_clock_handler_install(rtems_interrupt_handler handler)
@@ -79,8 +76,8 @@ static void arm_gt_clock_handler_install(void)
     arm_gt_clock_instance.irq,
     "Clock",
-    NULL
+    handler,
+    &arm_gt_clock_instance
     bsp_fatal(BSP_ARM_FATAL_GENERIC_TIMER_CLOCK_IRQ_INSTALL);
@@ -185,14 +182,14 @@ RTEMS_SYSINIT_ITEM(
-  arm_gt_clock_at_tick()
+  arm_gt_clock_at_tick(arg)
   arm_gt_clock_initialize()
-  arm_gt_clock_handler_install()
+  arm_gt_clock_handler_install(isr)
diff --git a/bsps/shared/dev/clock/clockimpl.h b/bsps/shared/dev/clock/clockimpl.h
index c58a6eb079..592046ec27 100644
--- a/bsps/shared/dev/clock/clockimpl.h
+++ b/bsps/shared/dev/clock/clockimpl.h
@@ -63,6 +63,13 @@
 #error "Fast Idle PLUS n ISRs per tick is not supported"
 #endif
+#if defined(BSP_FEATURE_IRQ_EXTENSION) || \
+    (CPU_SIMPLE_VECTORED_INTERRUPTS != TRUE)
+typedef void * Clock_isr_argument;
+#else
+typedef rtems_vector_number Clock_isr_argument;
+#endif
  * @brief Do nothing by default.
@@ -81,7 +88,7 @@
 #ifndef Clock_driver_support_at_tick
-  #define Clock_driver_support_at_tick()
+  #define Clock_driver_support_at_tick( arg ) do { (void) arg; } while (0)
 #endif
@@ -96,8 +103,9 @@
  * instead of the default.
 #ifndef Clock_driver_timecounter_tick
-static void Clock_driver_timecounter_tick( void )
+static void Clock_driver_timecounter_tick( Clock_isr_argument arg )
+  (void) arg;
 #if defined(CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER)
   rtems_clock_tick();
 #elif defined(RTEMS_SMP) && defined(CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR)
@@ -159,20 +167,11 @@ static bool _Clock_Has_watchdogs(const Per_CPU_Control *cpu)
  *  This is the clock tick interrupt handler.
- *  @param vector Vector number.
+ *  @param arg is the clock interrupt handler argument.
-#if defined(BSP_FEATURE_IRQ_EXTENSION) || \
-    (CPU_SIMPLE_VECTORED_INTERRUPTS != TRUE)
+void Clock_isr( Clock_isr_argument arg );
-#else
-rtems_isr Clock_isr(rtems_vector_number vector);
-  rtems_vector_number vector
-#endif
    *  Accurate count of ISRs
@@ -180,7 +179,7 @@ rtems_isr Clock_isr(
   #if CLOCK_DRIVER_USE_FAST_IDLE
-      Clock_driver_timecounter_tick();
+      Clock_driver_timecounter_tick( arg );
       if (_SMP_Get_processor_maximum() == 1) {
         struct timecounter *tc;
@@ -210,7 +209,7 @@ rtems_isr Clock_isr(
-      Clock_driver_support_at_tick();
+      Clock_driver_support_at_tick( arg );
   #else
@@ -218,14 +217,14 @@ rtems_isr Clock_isr(
      *  The counter/timer may or may not be set to automatically reload.
     #if CLOCK_DRIVER_ISRS_PER_TICK
        *  The driver is multiple ISRs per clock tick.
       if ( !Clock_driver_isrs ) {
         Clock_driver_isrs = CLOCK_DRIVER_ISRS_PER_TICK_VALUE;
@@ -234,7 +233,7 @@ rtems_isr Clock_isr(
        *  The driver is one ISR per clock tick.
     #endif
   #endif
diff --git a/bsps/shared/dev/clock/xil-ttc.c b/bsps/shared/dev/clock/xil-ttc.c
index 5121773a6f..340c428a48 100644
--- a/bsps/shared/dev/clock/xil-ttc.c
+++ b/bsps/shared/dev/clock/xil-ttc.c
@@ -157,7 +157,7 @@ static void zynqmp_ttc_clock_driver_support_initialize_hardware(void)
  * @retval Void
-static void zynqmp_ttc_clock_driver_support_at_tick( void )
+static void zynqmp_ttc_clock_driver_support_at_tick(ttc_clock_context *tc)
   uint32_t irq_flags;
   uint32_t cval;
@@ -181,49 +181,41 @@ static void zynqmp_ttc_clock_driver_support_at_tick( void )
     now = XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_COUNT_VALUE_OFFSET);
     delta = now - cval;
-    if(delta > ttc_clock_instance.irq_match_interval) {
+    if(delta > tc->irq_match_interval) {
      cval = now;
-     ttc_clock_instance.tick_miss++;
+     tc->tick_miss++;
-    cval += ttc_clock_instance.irq_match_interval;
+    cval += tc->irq_match_interval;
     XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET, cval);
   /* Else, something is set up wrong, only match should be enabled */
- * @brief registers RTI interrupt handler
- * @param[in] Clock_isr new ISR handler
- * @param[in] Old_ticker old ISR handler (unused and type broken)
- * @retval Void
 static void zynqmp_ttc_clock_driver_support_install_isr(
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  rtems_status_code sc;
     BSP_SELECTED_TTC_IRQ,
     "Clock",
-    NULL
+    handler,
+    &ttc_clock_instance
-  zynqmp_ttc_clock_driver_support_at_tick
+  zynqmp_ttc_clock_driver_support_at_tick(arg)
-  zynqmp_ttc_clock_driver_support_install_isr( Clock_isr )
+  zynqmp_ttc_clock_driver_support_install_isr(isr)
diff --git a/bsps/shared/grlib/btimer/tlib_ckinit.c b/bsps/shared/grlib/btimer/tlib_ckinit.c
index 8a5ee33842..e2179090fa 100644
--- a/bsps/shared/grlib/btimer/tlib_ckinit.c
+++ b/bsps/shared/grlib/btimer/tlib_ckinit.c
@@ -433,10 +433,10 @@ static const struct ops ops_irqamp = {
   } while (0)
-#define Clock_driver_timecounter_tick() \
+#define Clock_driver_timecounter_tick(arg) \
   tlib_clock_timecounter_tick()
   do { \
     rtems_device_driver ret; \
     ret = tlib_clock_at_tick(); \
diff --git a/bsps/sparc/erc32/clock/ckinit.c b/bsps/sparc/erc32/clock/ckinit.c
index e8cf7188eb..c0101c5839 100644
--- a/bsps/sparc/erc32/clock/ckinit.c
+++ b/bsps/sparc/erc32/clock/ckinit.c
@@ -51,12 +51,10 @@ uint32_t _CPU_Counter_frequency( void )
   return ERC32_REAL_TIME_CLOCK_FREQUENCY;
-static void erc32_clock_at_tick( void )
+static void erc32_clock_at_tick( SPARC_Counter *counter )
-  SPARC_Counter *counter;
   rtems_interrupt_level level;
-  counter = &_SPARC_Counter;
   rtems_interrupt_local_disable(level);
   ERC32_Clear_interrupt( ERC32_INTERRUPT_REAL_TIME_CLOCK );
@@ -110,7 +108,7 @@ RTEMS_SYSINIT_ITEM(
     "Clock", \
     RTEMS_INTERRUPT_SHARED, \
     _new, \
-    NULL \
+    &_SPARC_Counter \
 #define Clock_driver_support_set_interrupt_affinity( _online_processors ) \
@@ -118,7 +116,7 @@ RTEMS_SYSINIT_ITEM(
     (void) _online_processors; \
   } while (0)
-#define Clock_driver_support_at_tick() erc32_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) erc32_clock_at_tick(arg)
 #define Clock_driver_support_initialize_hardware() erc32_clock_init()
diff --git a/bsps/sparc/leon2/clock/ckinit.c b/bsps/sparc/leon2/clock/ckinit.c
index 31f8bca7ba..3aad931218 100644
--- a/bsps/sparc/leon2/clock/ckinit.c
+++ b/bsps/sparc/leon2/clock/ckinit.c
@@ -121,7 +121,7 @@ uint32_t _CPU_Counter_frequency( void )
     NULL \
-#define Clock_driver_support_at_tick() leon2_clock_at_tick()
+#define Clock_driver_support_at_tick(arg) leon2_clock_at_tick()
 #define Clock_driver_support_initialize_hardware() leon2_clock_init()
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index d530f260a8..f0307bf908 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -202,7 +202,7 @@ static void leon3_clock_initialize(void)
   leon3_clock_initialize()
-#define Clock_driver_timecounter_tick() leon3_tc_do_tick()
+#define Clock_driver_timecounter_tick(arg) leon3_tc_do_tick()
 #define BSP_FEATURE_IRQ_EXTENSION
diff --git a/bsps/sparc64/shared/clock/ckinit.c b/bsps/sparc64/shared/clock/ckinit.c
index 7c97ba3177..82ac3b1995 100644
--- a/bsps/sparc64/shared/clock/ckinit.c
+++ b/bsps/sparc64/shared/clock/ckinit.c
@@ -63,7 +63,7 @@ static unsigned int get_Frequency(void)
   return freq;
   Clock_driver_support_at_tick_helper()
 static void Clock_driver_support_at_tick_helper(void)
2.35.3
