[PATCH 2/5] bsps: Use bsps/arm/xilinx-zynqmp-rpu
Kinsey Moore kinsey.moore at oarcorp.com
Fri Mar 22 15:38:11 UTC 2024
This patch looks good.
Kinsey
On Mon, Mar 18, 2024 at 11:30 AM Sebastian Huber <
>  spec/build/bsps/objxilinxsupportr5.yml | 3 +--
>  spec/build/bsps/optxilsupportpath.yml  | 2 +-
>  2 files changed, 2 insertions(+), 3 deletions(-)
> diff --git a/spec/build/bsps/objxilinxsupportr5.yml
> b/spec/build/bsps/objxilinxsupportr5.yml
> index d800b83247..25221c5e0d 100644
> --- a/spec/build/bsps/objxilinxsupportr5.yml
> +++ b/spec/build/bsps/objxilinxsupportr5.yml
> @@ -5,8 +5,7 @@ copyrights:
>  - Copyright (C) 2022 On-Line Applications Research (OAR)
>  cppflags: []
>  cxxflags: []
> -enabled-by:
> -- arm/xilinx_zynqmp_mercuryxu5_rpu
> +enabled-by: bsps/arm/xilinx-zynqmp-rpu
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}
> diff --git a/spec/build/bsps/optxilsupportpath.yml
> b/spec/build/bsps/optxilsupportpath.yml
> index 85bcc7e059..298f9d5286 100644
> --- a/spec/build/bsps/optxilsupportpath.yml
> +++ b/spec/build/bsps/optxilsupportpath.yml
> @@ -7,7 +7,7 @@ copyrights:
>  default:
>  - enabled-by:
> -  - arm/xilinx_zynqmp_mercuryxu5_rpu
> +  - bsps/arm/xilinx-zynqmp-rpu
>    value: arm/cortexr5
>  - enabled-by: bsps/microblaze/microblaze_fpga
>    value: microblaze
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240322/ea596d4f/attachment.htm>
