[PATCH] bsp-howto: Document clock driver arg parameter
Fri Mar 22 19:50:50 UTC 2024
LGTM, thanks!
On Fri, Mar 22, 2024 at 1:11 AM Sebastian Huber
> Update #4862.
>  bsp-howto/clock.rst | 34 ++++++++++++++++++++++------------
>  1 file changed, 22 insertions(+), 12 deletions(-)
> diff --git a/bsp-howto/clock.rst b/bsp-howto/clock.rst
> index 043083f..ed83472 100644
> --- a/bsp-howto/clock.rst
> +++ b/bsp-howto/clock.rst
> @@ -139,6 +139,9 @@ Simple Timecounter Variant
>  For an example see the `ERC32 clock driver
>  <https://git.rtems.org/rtems/tree/bsps/sparc/erc32/clock/ckinit.c>`_.
> +The argument parameter of ``Clock_driver_timecounter_tick( arg )`` is the
> +argument used to install the clock interrupt handler.  Device drivers may use
> +this argument to access their control state.
>  .. code-block:: c
> @@ -165,9 +168,9 @@ For an example see the `ERC32 clock driver
> -    static void some_tc_tick( void )
> +    static void some_tc_tick( rtems_timecounter_simple *tc )
> -      rtems_timecounter_simple_downcounter_tick( &some_tc, some_tc_get );
> +      rtems_timecounter_simple_downcounter_tick( tc, some_tc_get );
>      static void some_support_initialize_hardware( void )
> @@ -193,8 +196,8 @@ For an example see the `ERC32 clock driver
>      #define Clock_driver_support_initialize_hardware() \
>        some_support_initialize_hardware()
> -    #define Clock_driver_timecounter_tick() \
> -      some_tc_tick()
> +    #define Clock_driver_timecounter_tick( arg ) \
> +      some_tc_tick( arg )
>      #include "../../../shared/dev/clock/clockimpl.h"
> @@ -224,15 +227,20 @@ Install Clock Tick Interrupt Service Routine
>  The clock driver may provide a function to install the clock tick interrupt
> -service routine via ``Clock_driver_support_install_isr()``.  The clock tick
> -interrupt service routine is passed as the one and only parameter to this
> -macro.  The default implementation will do nothing.
> +service routine via ``Clock_driver_support_install_isr( isr )``.  The clock
> +tick interrupt service routine is passed as the one and only parameter to this
> +macro.  The default implementation will do nothing.  The argument parameter (in
> +the code below ``&some_instance``) for the installed interrupt handler is
> +available in the ``Clock_driver_support_at_tick( arg )`` and
> +``Clock_driver_support_initialize_hardware( arg )`` customization macros.
>  .. code-block:: c
>      #include <bsp/irq.h>
>      #include <bsp/fatal.h>
> +    static some_control some_instance;
>      static void some_support_install_isr( rtems_interrupt_handler isr )
>        rtems_status_code sc;
> @@ -241,7 +249,7 @@ macro.  The default implementation will do nothing.
>          "Clock",
>          RTEMS_INTERRUPT_UNIQUE,
>          isr,
> -        NULL
> +        &some_instance
>        if ( sc != RTEMS_SUCCESSFUL ) {
>          bsp_fatal( SOME_FATAL_IRQ_INSTALL );
> @@ -257,17 +265,19 @@ Support At Tick
>  The hardware-specific support at tick is specified by
> -``Clock_driver_support_at_tick()``.
> +``Clock_driver_support_at_tick( arg )``.  The ``arg`` is the argument used to
> +install the clock interrupt handler.  Device drivers may use this argument to
> +access their control state.
>  .. code-block:: c
> -    static void some_support_at_tick( void )
> +    static void some_support_at_tick( some_control *arg )
>        /* Clear interrupt */
> -    #define Clock_driver_support_at_tick() \
> -      some_support_at_tick()
> +    #define Clock_driver_support_at_tick( arg ) \
> +      some_support_at_tick( arg )
> 2.35.3
> devel mailing list
> devel at rtems.org
