[PATCH 13/16] Alphabetized INCLUDE_xx macros for ease of visibility
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 18:23:15 UTC 2015
ports/beagleboneblack/config.h | 78 +++++++++++++++++++++---------------------
1 file changed, 39 insertions(+), 39 deletions(-)
diff --git a/ports/beagleboneblack/config.h b/ports/beagleboneblack/config.h
index c700b6a..096bbda 100644
--- a/ports/beagleboneblack/config.h
+++ b/ports/beagleboneblack/config.h
@@ -155,58 +155,58 @@
/* descriptions of INCLUDE_xx macros are placed here for quick acess */
-#define INCLUDE_MEMTRACE 0 // enable simple memory tracing, simple
printf()-like function that
- // logs data instead of to UART
-#define INCLUDE_MEMCMDS 0 // memory display, modification and
test commands (see memcmds.c)
+#define INCLUDE_BBC 0 // enable some code and a CLI
command to provide an application
+ // with a basic ability to organize basic block coverage
+ // verification
+#define INCLUDE_CAST 0 // enable 'cast' command for
complex structure display at the CLI
+#define INCLUDE_DHCPBOOT 0 // enable the DHCP/BOOTP client,
requires ethernet
+#define INCLUDE_DISASSEMBLER 0 // pulls in a disassembler
+#define INCLUDE_DNS 0
#define INCLUDE_EDIT 0 // ascii file editor to edit files
in TFS (see edit.c); requires
// TFS and flash drivers to also be enabled
-#define INCLUDE_DISASSEMBLER 0 // pulls in a disassembler
-#define INCLUDE_UNZIP 0 // zlib stuff
-#define INCLUDE_ETHERNET 0 // ethernet drivers with ARP with
some low level ethernet code
-#define INCLUDE_ICMP 0
-#define INCLUDE_TFTP 0 // TFTP client and server, assumes
ethernet is enabled
-#define INCLUDE_DHCPBOOT 0 // enable the DHCP/BOOTP client,
requires ethernet
-#define INCLUDE_TFS 0 // required by other TFS macros,
provides basic TFS functionality
-#define INCLUDE_TFSCLI 0 // enable TFS command on the command line
-#define INCLUDE_TFSAPI 0 // TFS hooks for use by applications
-#define INCLUDE_TFSSCRIPT 0 // enables CLI commands associated
with scripts
-#define INCLUDE_TFSSYMTBL 0 // enable symbol-table functionality
-#define INCLUDE_XMODEM 0 // enable xmodem
-#define INCLUDE_LINEEDIT 0 // enable command line editor and history
#define INCLUDE_EE 0 // expression evaluator
+#define INCLUDE_ETHERNET 0 // ethernet drivers with ARP with
+#define INCLUDE_FBI 0
#define INCLUDE_FLASH 0 // enable flash drivers
-#define INCLUDE_STRACE 0 // enable 'strack trace' command
-#define INCLUDE_CAST 0 // enable 'cast' command for
-#define INCLUDE_STRUCT 0 // enable the struct command, requires TFS
-#define INCLUDE_REDIRECT 0 // enable monitor's CLI to redirect
command output to a TFS file
-#define INCLUDE_QUICKMEMCPY 0 // enable faster memory stuff in genlib.c
-#define INCLUDE_PROFILER 0 // enable some code and a CLI
- // with some task and function level profiling
-#define INCLUDE_BBC 0 // enable some code and a CLI
- // with a basic ability to organize basic block coverage
- // verification
-#define INCLUDE_STOREMAC 0 // force user to establish MAC in
the etheradd space allocated in
- // reset.s; requires flash drivers
-#define INCLUDE_SHELLVARS 0 // enable shell variable functionality in
the monitor
-#define INCLUDE_MALLOC 0 // enable monitor's malloc, 'heap' command on the CLI
-#define INCLUDE_PORTCMD 0 // if set, the mon_portcmd(int cmd,
void *arg) API can be used
- // to build port-specific API extensions
-#define INCLUDE_SYSLOG 0
#define INCLUDE_HWTMR 0 // if set, the target port must supply
a function called
// target_timer() which returns a 32-bit value representing
// a hardware-resident clock whose rate is defined by
// TIMER_TICKS_PER_MSEC
-#define INCLUDE_VERBOSEHELP 0 // enable full help text
#define INCLUDE_GDB 0 // enable 'gdb' command, incomplete facility
with the eventual
goal of hooking up to a gdb debugger
-#define INCLUDE_USRLVL 0 // if set, code that incorporates user
levels is included in the
- // build
+#define INCLUDE_ICMP 0
#define INCLUDE_JFFS2 0
#define INCLUDE_JFFS2ZLIB 0
-#define INCLUDE_FBI 0
-#define INCLUDE_TSI 0
+#define INCLUDE_LINEEDIT 0 // enable command line editor and history
+#define INCLUDE_MALLOC 0 // enable monitor's malloc, 'heap' command on the CLI
+#define INCLUDE_MEMCMDS 0 // memory display, modification and
+#define INCLUDE_MEMTRACE 0 // enable simple memory tracing, simple
+ // logs data to RAM instead of to UART
+#define INCLUDE_PORTCMD 0 // if set, the mon_portcmd(int cmd,
+ // to build port-specific API extensions
+#define INCLUDE_PROFILER 0 // enable some code and a CLI
+ // with some task and function level profiling
+#define INCLUDE_QUICKMEMCPY 0 // enable faster memory stuff in genlib.c
+#define INCLUDE_REDIRECT 0 // enable monitor's CLI to redirect
#define INCLUDE_SD 0
-#define INCLUDE_DNS 0
+#define INCLUDE_SHELLVARS 0 // enable shell variable functionality in
the monitor
+#define INCLUDE_STOREMAC 0 // force user to establish MAC in
+ // reset.s; requires flash drivers
+#define INCLUDE_STRACE 0 // enable 'strack trace' command
+#define INCLUDE_STRUCT 0 // enable the struct command, requires TFS
+#define INCLUDE_SYSLOG 0
+#define INCLUDE_TFS 0 // required by other TFS macros,
+#define INCLUDE_TFSAPI 0 // TFS hooks for use by applications
+#define INCLUDE_TFSCLI 0 // enable TFS command on the command line
+#define INCLUDE_TFSSCRIPT 0 // enables CLI commands associated
with scripts
+#define INCLUDE_TFSSYMTBL 0 // enable symbol-table functionality
+#define INCLUDE_TFTP 0 // TFTP client and server, assumes
ethernet is enabled
+#define INCLUDE_TSI 0
+#define INCLUDE_UNZIP 0 // zlib stuff
+#define INCLUDE_XMODEM 0 // enable xmodem
+#define INCLUDE_VERBOSEHELP 0 // enable full help text
+#define INCLUDE_USRLVL 0 // if set, code that incorporates user
+ // build
/* Inclusion of this next file will make sure that all of the above
* inclusions are legal; and warn/adjust where necessary.
2.3.3
More information about the umon-devel
