How to remove i387 from the system?
Stream Labs STREAM.L at G23.RELCOM.RU
Sat Apr 15 13:53:50 UTC 2000
Hello All,
I have a working RTEMS application for pc486 target and want to run it on a
simplified i386 machine. What should I do to remove 387 coprocessor from the
system, which is
lacking here, to do it in the most correct way.
Thank you, best regards,  Ivan Romanov. <STREAM.L at g23.relcom.ru>
