Building Coldfire 5307 BSP under 4.5-beta3?
Dario Alcocer dalcocer at home.com
Thu Jun 8 16:28:06 UTC 2000
I've not found the mailing list archives on the new web site, so I
guess I'll have to waste some mailing-list bandwidth and ask: are
there any patches that need to be applied to David Fiddes' SBC5307 BSP
in order for it to build on 4.5-beta3?
After unpacking the Coldfire BSPs in the correct directory, I ran the
build script:
    $ ./bit_rtems m68k sbc5307
However, this generated the following errors in GNU Make:
    Making preinstall in sbc5307
    gmake[7]: Entering directory
    `/usr/local/rtems/tools/build-m68k-rtems/m68k-rtems/c/sbc5307/lib/libbsp/m68k/sbc5307'
    gmake[7]: *** No rule to make target `preinstall'.  Stop.
Evidently, there's a missing makefile target, and before I start
hacking it, I wanted to know if anyone else had run across this, and
what the correct fix for this error is.
Thanks in advance.
Dario Alcocer // dalcocer at home.com
