Network buffers, MPC860 and data caching
Till Straumann strauman at SLAC.Stanford.EDU
Fri Oct 27 23:00:47 UTC 2000
Charles-Antoine Gauthier wrote:
> > Have a look at Charles Gauthier's & Darlene Steward's MBX BSP in the
> > current snapshot. It goes a different route: All RAM is cacheable,
> > however, once CPM buffers (not only for network) are touched, explicit
> > cache commands for the memory covered by the buffer are used:
> >    - on output buffers, caches are flushed after writing and before
> >      setting the ready bit
> >    - on read, the cache lines for the buffer are invalidated before
> >      reading the buffer
Ok, that's what I want to do on the MPC860 powerpc FADS board.
I thought about how to implement this because I saw that the network and
console drivers use `malloc()ed' buffers. This complicates things because,
obviously, receive buffers must be cache line aligned. AFAIK network
receiving buffers are allocated by the driver, passed upstream and are
also deallocated upstream.
Eventually, I decided to download the latest snapshot and have a look at
your implementation. I could see that your  `rtems_cache_aligned_malloc()'
looks pretty much like what was my first idea.
However, (and that's the problem stumbled over), how does `free()' like
the modified address returned by `rtems_cache_aligned_malloc'()? I'm
afraid not very much - it seems to me that free()ing
cache_aligned_malloc()ed memory results in heap corruption :-)
-- Till.
