How to set file permissions in Init task?
Thu Jan 25 13:37:22 UTC 2001
OUTWATER ~ KEITH J /5G3110 wrote:
> Greetings all -
> I use Untar_Frommemory() to set up an initial file system which includes a
> "/tmp" directory.
> I am attempting to make this directory read/write by everyone in the Init task,
> but chmod() fails (not owner).
> Where, then, is the right place to set this permission?
Before you create the tar image.   My thinking is that the image on your
local disk before you tar is exactly what you want to untar, permissions
included.  There might be some tricks with seteuid() or something to make
this work out easier.  I would not expect you to need to change permissions
after untar'ing.
> Thanks!
> Keith
> Keith Outwater
> Principal Engineer
> Raytheon Missile Systems
> Tucson, AZ
> (520) 794-2518
> vac4050 at nospam.cae597.rsc.raytheon.com
