termios wakeup callback functions
Angelo Fraietta angelo at hunterlink.net.au
Fri Jul 20 01:54:10 UTC 2001
This patch did not make it into the last snapshot.
How do I implement this patch (the standard | patch -p1 doesn't work)?
Mike Siers wrote:
>  Hi,The attached patch file will provide the ability to specify
> somewakeup callback functions for termios.  Basically, this definesa
> ttywakeup structure that is similar to the socket wakeupstructure.
> The tty wakeup structures are set by using theioctl
> function. Basically, you use
> the RTEMS_IO_RCVWAKEUP or RTEMS_IO_SNDWAKEUP ioctl commands and pass
> in an address to a ttywakeup structure. The wakeup functions
> are called if data has been received on a tty or if the send
> buffer has become empty on the tty.The patch file was created
> from the 2001/05/25 snapshot.Good LuckMike Siers
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://users.hunterlink.net.au/~maaaf/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is
VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20010720/a186c72a/attachment-0001.html>
