MC68331 GPT header file
mcollins at hawkeye.sps.mot.com mcollins at hawkeye.sps.mot.com
Fri Mar 23 00:35:04 UTC 2001
  Appended is a header file for the MC68331 general purpose timer.  It
closely follows the conventions used in other m68k header files used
by the efi332 BSP.
 *      MC68331 General Purpose Timer definitions
 * Notes:
 *   1. Register and bit addresses are dependent upon register sizes;
 *      16-bit registers documented as two concatenated 8-bit registers
 *      (i.e., GPT PDDR/PDR) are defined as separate 8-bit registers.
 *   2. Register names are concatenation of gpt_<name>, where <name> is
 *      register name as documented in MC68331 User's Manual.
 *   3. Test registers are not defined within this file.
 *   4. This file follows the conventions used within "sim.h".
 *  These macros make this file usable from assembly.
#ifdef ASM
#define SIM_VOLATILE_USHORT_POINTER
#define SIM_VOLATILE_UCHAR_POINTER
#else
#define SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const)
#define SIM_VOLATILE_UCHAR_POINTER  (volatile unsigned char * const)
#endif
 * GPT_CRB (GPT Control Register Block) base address of the GPT
 * control registers
 * Note: Not certain that SIM_MM will always be known when this file is
 *       processed.  If not, it may be necessary to hard-code GPT_CRB.
#if SIM_MM == 0
#define GPT_CRB 0x7ff900
#else
#undef SIM_MM
#define GPT_MM 1
#define GPT_CRB 0xfff900
#endif
 * end not included in ram_init.h
 * Configuration Register (MCR)
#define GPT_MCR SIM_VOLATILE_USHORT_POINTER (0x00 + GPT_CRB)
#define GPT_STOP  (1 << 15)
#define GPT_FRZ1  (1 << 14)
#define GPT_FRZ0  (1 << 13)
#define GPT_STOPP (1 << 12)
#define GPT_INCP  (1 << 11)
#define GPT_SUPV  (1 <<  7)
#define GPT_IARB3 (1 <<  3)
#define GPT_IARB2 (1 <<  2)
#define GPT_IARB1 (1 <<  1)
#define GPT_IARB0 (1 <<  0)
 * Interrupt Configuration Register (ICR)
#define GPT_ICR SIM_VOLATILE_USHORT_POINTER (0x04 + GPT_CRB)
 * GPT Interrupt vectors are the sum of IVBA (ICR[7:4]) and vector
 * values shown below.  The first definition is for the Adjust Channel.
#define GPT_AC_VECTOR     (1 <<  0)
#define GPT_IC1_VECTOR    (1 <<  1)
#define GPT_IC2_VECTOR    (1 <<  2)
#define GPT_IC3_VECTOR    (1 <<  3)
#define GPT_OC1_VECTOR    (1 <<  4)
#define GPT_OC2_VECTOR    (1 <<  5)
#define GPT_OC3_VECTOR    (1 <<  6)
#define GPT_OC4_VECTOR    (1 <<  7)
#define GPT_IC4OC5_VECTOR (1 <<  8)
#define GPT_TOF_VECTOR    (1 <<  9)
#define GPT_PAOVF_VECTOR  (1 << 10)
#define GPT_PAIF_VECTOR   (1 << 11)
 *  Parallel Data Direction Register (PDDR)
#define GPT_PDDR SIM_VOLATILE_UCHAR_POINTER (0x06 + GPT_CRB)
#define GPT_DDRI4O5  (1 <<  7)
#define GPT_DDRO4    (1 <<  6)
#define GPT_DD5O3    (1 <<  5)
#define GPT_DDRO2    (1 <<  4)
#define GPT_DDRO1    (1 <<  3)
#define GPT_DDRI3    (1 <<  2)
#define GPT_DDRI2    (1 <<  1)
#define GPT_DDRI1    (1 <<  0)
 * Parallel Data Register (PDR)
#define GPT_PDR SIM_VOLATILE_UCHAR_POINTER (0x07 + GPT_CRB)
#define GPT_IC4OC5  (1 <<  7)
#define GPT_OC4     (1 <<  6)
#define GPT_OC3     (1 <<  5)
#define GPT_OC2     (1 <<  4)
#define GPT_OC1     (1 <<  3)
#define GPT_IC3     (1 <<  2)
#define GPT_IC2     (1 <<  1)
#define GPT_IC1     (1 <<  0)
 * OC1 Action Mask Register (OC1M)
#define GPT_OC1M SIM_VOLATILE_UCHAR_POINTER (0x08 + GPT_CRB)
#define GPT_OC1M7  (1 <<  7)
#define GPT_OC1M6  (1 <<  6)
#define GPT_OC1M5  (1 <<  5)
#define GPT_OC1M4  (1 <<  4)
#define GPT_OC1M3  (1 <<  3)
 * OC1 Action Data Register (OC1D)
#define GPT_OC1D SIM_VOLATILE_UCHAR_POINTER (0x09 + GPT_CRB)
#define GPT_OC1D7  (1 <<  7)
#define GPT_OC1D6  (1 <<  6)
#define GPT_OC1D5  (1 <<  5)
#define GPT_OC1D4  (1 <<  4)
#define GPT_OC1D3  (1 <<  3)
 * Counter Register (TCNT)
#define GPT_TCNT SIM_VOLATILE_USHORT_POINTER (0x0a + GPT_CRB)
 * Pulse Accumulator Control Register (PACTL)
#define GPT_PACTL SIM_VOLATILE_UCHAR_POINTER (0x0c + GPT_CRB)
#define GPT_PAIS    (1 <<  7)
#define GPT_PAEN    (1 <<  6)
#define GPT_PAMOD   (1 <<  5)
#define GPT_PEDGE   (1 <<  4)
#define GPT_PCLKS   (1 <<  3)
#define GPT_I4O5    (1 <<  2)
#define GPT_PACLK1  (1 <<  1)
#define GPT_PACLK0  (1 <<  0)
 * Pulse Accumulator Counter Register (PACNT)
#define GPT_PACNT SIM_VOLATILE_UCHAR_POINTER (0x0d + GPT_CRB)
#define GPT_PACNT7  (1 <<  7)
#define GPT_PACNT6  (1 <<  6)
#define GPT_PACNT5  (1 <<  5)
#define GPT_PACNT4  (1 <<  4)
#define GPT_PACNT3  (1 <<  3)
#define GPT_PACNT2  (1 <<  2)
#define GPT_PACNT1  (1 <<  1)
#define GPT_PACNT0  (1 <<  0)
 * Input Capture Register 1 (TIC1)
#define GPT_TIC1 SIM_VOLATILE_USHORT_POINTER (0x0e + GPT_CRB)
 * Input Capture Register 2 (TIC2)
#define GPT_TIC2 SIM_VOLATILE_USHORT_POINTER (0x10 + GPT_CRB)
 * Input Capture Register 3 (TIC3)
#define GPT_TIC3 SIM_VOLATILE_USHORT_POINTER (0x12 + GPT_CRB)
 * Output Compare Register 1 (TOC1)
#define GPT_TOC1 SIM_VOLATILE_USHORT_POINTER (0x14 + GPT_CRB)
 * Output Compare Register 2 (TOC2)
#define GPT_TOC2 SIM_VOLATILE_USHORT_POINTER (0x16 + GPT_CRB)
 * Output Compare Register 3 (TOC3)
#define GPT_TOC3 SIM_VOLATILE_USHORT_POINTER (0x18 + GPT_CRB)
 * Output Compare Register 4 (TOC4)
#define GPT_TOC4 SIM_VOLATILE_USHORT_POINTER (0x1a + GPT_CRB)
 * Input Capture 4/Ouput Compare 5 Register (TI4O5)
#define GPT_TI4O5 SIM_VOLATILE_USHORT_POINTER (0x1c + GPT_CRB)
 * Control Register 1 (TCTL1)
#define GPT_TCTL1 SIM_VOLATILE_UCHAR_POINTER (0x1e + GPT_CRB)
#define GPT_OM5  (1 <<  7)
#define GPT_OL5  (1 <<  6)
#define GPT_OM4  (1 <<  5)
#define GPT_OL4  (1 <<  4)
#define GPT_OM3  (1 <<  3)
#define GPT_OL3  (1 <<  2)
#define GPT_OM2  (1 <<  1)
#define GPT_OL2  (1 <<  0)
 * Control Register 2 (TCTL2)
#define GPT_TCTL2 SIM_VOLATILE_UCHAR_POINTER (0x1f + GPT_CRB)
#define GPT_EDGE4B  (1 <<  7)
#define GPT_EDGE4A  (1 <<  6)
#define GPT_EDGE3B  (1 <<  5)
#define GPT_EDGE3A  (1 <<  4)
#define GPT_EDGE2B  (1 <<  3)
#define GPT_EDGE2A  (1 <<  2)
#define GPT_EDGE1B  (1 <<  1)
#define GPT_EDGE1A  (1 <<  0)
 * Interrupt Mask Register 1 (TMSK1)
#define GPT_TMSK1 SIM_VOLATILE_UCHAR_POINTER (0x20 + GPT_CRB)
#define GPT_I4O5I  (1 <<  7)
#define GPT_OC4I   (1 <<  6)
#define GPT_OC3I   (1 <<  5)
#define GPT_OC2I   (1 <<  4)
#define GPT_OC1I   (1 <<  3)
#define GPT_IC3I   (1 <<  2)
#define GPT_IC2I   (1 <<  1)
#define GPT_IC1I   (1 <<  0)
 * Interrupt Mask Register 2 (TMSK2)
#define GPT_TMSK2 SIM_VOLATILE_UCHAR_POINTER (0x21 + GPT_CRB)
#define GPT_TOI     (1 <<  7)
#define GPT_PAOVI   (1 <<  5)
#define GPT_PAII    (1 <<  4)
#define GPT_CPROUT  (1 <<  3)
#define GPT_CPR2    (1 <<  2)
#define GPT_CPR1    (1 <<  1)
#define GPT_CPR0    (1 <<  0)
 * Interrupt Flag Register 1 (TFLG1)
#define GPT_TFLG1 SIM_VOLATILE_UCHAR_POINTER (0x22 + GPT_CRB)
#define GPT_I4O5F  (1 <<  7)
#define GPT_OC4F   (1 <<  6)
#define GPT_OC3F   (1 <<  5)
#define GPT_OC2F   (1 <<  4)
#define GPT_OC1F   (1 <<  3)
#define GPT_IC3F   (1 <<  2)
#define GPT_IC2F   (1 <<  1)
#define GPT_IC1F   (1 <<  0)
 * Interrupt Flag Register 2 (TFLG2)
 * TOF bit defined above.
#define GPT_TFLG2 SIM_VOLATILE_UCHAR_POINTER (0x22 + GPT_CRB)
#define GPT_PAOVF  (1 <<  5)
#define GPT_PAIF   (1 <<  4)
 * Compare Force Register (CFORC)
#define GPT_CFORC SIM_VOLATILE_UCHAR_POINTER (0x24 + GPT_CRB)
#define GPT_FOC5   (1 <<  7)
#define GPT_FOC4   (1 <<  6)
#define GPT_FOC3   (1 <<  5)
#define GPT_FOC2   (1 <<  4)
#define GPT_FOC1   (1 <<  3)
#define GPT_FPWMA  (1 <<  1)
#define GPT_FPWMB  (1 <<  0)
 * PWM Control Register (PWMC)
#define GPT_PWMC SIM_VOLATILE_UCHAR_POINTER (0x25 + GPT_CRB)
#define GPT_PPROUT  (1 <<  7)
#define GPT_PPR2    (1 <<  6)
#define GPT_PPR1    (1 <<  5)
#define GPT_PPR0    (1 <<  4)
#define GPT_SFA     (1 <<  3)
#define GPT_SFB     (1 <<  2)
#define GPT_F1A     (1 <<  1)
#define GPT_F1B     (1 <<  0)
 * PWM Register A (PWMA)
#define GPT_PWMA SIM_VOLATILE_UCHAR_POINTER (0x26 + GPT_CRB)
 * PWM Register B (PWMB)
#define GPT_PWMB SIM_VOLATILE_UCHAR_POINTER (0x27 + GPT_CRB)
 * PWM Count Register (PWMCNT)
#define GPT_PWMCNT SIM_VOLATILE_USHORT_POINTER (0x28 + GPT_CRB)
 * PWM Buffer Register A (PWMABUF)
#define GPT_PWMABUF SIM_VOLATILE_UCHAR_POINTER (0x2a + GPT_CRB)
 * PWM Buffer Register B (PWMBBUF)
#define GPT_PWMBBUF SIM_VOLATILE_UCHAR_POINTER (0x2b + GPT_CRB)
 * GPT Prescaler (PRESCL)
#define GPT_PRESCL SIM_VOLATILE_USHORT_POINTER (0x2c + GPT_CRB)
