make error building i960-rtems under cygwin-b20
Sanford Liao sliao at runtop.com.tw
Wed May 2 13:33:47 UTC 2001
Hello,
I try to build an i960 version of rtems, but now I got this error. The following is my configuration:
    ../rtems-4.5.0/configure --target=i960-rtems --disable-posix --disable-tcpip --disable-cxx --enable-rtemsbsp=rxgen960 --prefix=/opt/rtems
and the following is the error messages:
make[5]: Entering directory `/usr/local/src/redhat/tools/build-rtems/i960-rtems/c/rxgen960/exec/score/cpu'
Making all in i960
make[6]: Entering directory `/usr/local/src/redhat/tools/build-rtems/i960-rtems/c/rxgen960/exec/score/cpu/i960'
Makefile:406: *** target pattern contains no `%'.  Stop.
make[6]: Leaving directory `/usr/local/src/redhat/tools/build-rtems/i960-rtems/c/rxgen960/exec/score/cpu/i960'
Does anyone have an idea?
At the moment I use rtems 4.5.0, cygwin-b20 and Window 2000 server.
Sanford Liao
E-Mail: sliao at runtop.com.tw <mailto:sliao at runtop.com.tw>
URL: <http://lists.rtems.org/pipermail/users/attachments/20010502/7af01749/attachment.html>
