arm-rtems-gcc...no
Sudheesh J sudheesh at ATINAV.COM
Thu Nov 21 07:09:42 UTC 2002
Sorry if I interpret you incorrectly. You said mere gcc-3.2.targ.gz. And the error messages also indicate the same. You have to apply the RTEMS patch. Or you have to export the cross compiler path to the PATH environment variable. The other tools also should be patched. It says arm-rtems-gcc not found.. not gcc.  Refer the fileTOOLVERSIONS in the same ftp directory as the source archive.  Then compile them for the target processor(arm). Or you may use the patched tools available at ftp://ftp.oarcorp.com/pub/rtems/releases/4.5.0/c_tools
regards,
Sudheesh
Sudheesh Joseph Oppamthadathil
Atinav Incorporated
www.atinav.com
----- Original Message -----
  To: rtems-users at OARcorp.com
  Sent: Thursday, November 21, 2002 12:29 PM
  Subject: arm-rtems-gcc...no
  hi all.
      I am using snapshot "rtems-ss-20021111".
      My configure options are below.
      ../rtems-ss-20021111/configure --target=arm-rtems
      --enable-posix --disable-itron --enable-networking
      --disable-cxx --enable--rtemsbsp=arm_bare_bsp
      --prefix=/usr/src/redhat/install/
      and the result are :
      ... ( omit )
      checking for arm-rtems-gcc...no
      configure:error:no acceptable cc found in $PATH
      configure:error:/bin/sh '../../../../rtems-ss-20021111/c/make/configure' failed for c/make
      sed:can't read confdefs.h: No such file or directory
      I've installed gcc-3.2.tar.gz
      and there is confdefs.h in the directory where I run my configure.
      why compiler can't find the confdefs.h ?
      Please help me !
      Thank you in advance.
      Howard.
URL: <http://lists.rtems.org/pipermail/users/attachments/20021121/2e848ca6/attachment-0001.html>
