Undefined reference to rtems_bsdnet_config
Thu Oct 31 18:14:54 UTC 2002
> Sudheesh J wrote:
> Hi,
>         Sorry for bugging you again. While trying to build a simple
> networking app, an undefined reference to rtems_bsdnet_config was
> produced.
That's the network configuration file and it is up to you to define
that structure.  See the networkconfig.h  file in the top directory
of the network demos.
> I'm using m68k bsk efi332.
This BSP doesn't have a NIC driver.  Do you have a NIC on your 332
board?
SOunds like you need a driver.
It is possible to use the loopback interface but that won't connect
you to another system.
> thank you for any help.
> Sudheesh
