GDB 5.2 Line number out of range error
Derick Hammond derick at perkinstechnologies.com.au
Mon Mar 17 05:43:20 UTC 2003
Hello all:
I have recently started using the RTEMS v. 4.6.0pre1, and have spent a
couple of days updating my tools, and bringing my Eval board BSP (M5206eC3)
into the source tree.
However, when running:
     $m68k-bdm-rtems-gdb -x /opt/rtems/lib/gdbScripts/RTEMS5206.gdb hello.exe
and setting a break point on "bsp_cleanup" I get the following:
     Breakpoint 4 at 0x380aac: file
../../../../../../../../../cvs_wa/rtems/c/src/lib/libbsp/m68k/m5206ec3/startup/bspclean.c,
line 150.
Even though this file is actually only 38 lines long.
Then when I "continue" within gdb I get:
     Continuing.
     Breakpoint 4, bsp_cleanup () at
line 150.
     Line number 150 out of range;
has 38 lines.
Does anyone with more experience with GDB know of any reason why this would
be occurring?
I compiled the m68k-bdm-rtems-gdb from:
     source: gdb-5.2.tar.gz
     RTEMS patches: gdb-5.2-rtems-base-20030211.diff
                               gdb-5.2-rtems-cg-20030211.diff
                               gdb-5.2-rtems-rdbg-20030211.diff
     Cybertech patch: gdb-5.2.1.patch
Thanks in advance.
Regards,
Derick Hammond
