Syslog
Till Straumann strauman at slac.stanford.edu
Wed Feb 25 17:27:04 UTC 2004
Richard M. Barry wrote:
>Am I right in assuming the following:
>To use a syslog in an RTEMS application, I have to import syslog.h, implement the syslog() call myself and then have some syslog daemon that writes the data to a file (assuming I want the log to be in a file)?
If you want it write it to a file local to the RTEMS machine, yes.
You can do remote logging (to UDP port 514 of a host computer) out of
the box.
It is necessary to call 'openlog' prior to any 'syslog' activity.
Look at the implementation in
cpukit/libnetworking/lib/syslog.c
HTH
-- Till
PS:
On the host, use the '-r' option to syslogd for it to accept remote
messages.
>Richard
