Help with Bochs Needed
Richardson, Anthony ar63 at evansville.edu
Mon Oct 25 12:15:53 UTC 2004
I can't seem to get applications running under
Bochs.  I'm trying to get the hello example running.
I'm using RTEMS 4.6.2 under cygwin.  I configure
using the i386-rtems target and the pc386 BSP.
Everything seems to compile and build without any
problems.
I copy the hello.exe to my hard disk image and start
Bochs.  At the grub prompt I type:
   root (hd0,0)
   kernel /hello.exe
and grub responds
   [Multiboot-elf, <0x100000:0x18fc4:0x2768>, shtab=0x11c140,
entry=0x10000c]
which seems to indicate that grub recognizes it as a proper kernel
anyway.
I then type (at the grub prompt):
   boot
The bochs screen goes blank, but then nothing is displayed.
I've tried some of the other examples with similar results.
Am I doing something incorrectly or am I overlooking something?
Any help is greatly appreciated.
Tony Richardson
