.initial [03ff1920 -> 03ff1b58] overlaps ERROR
Charles Ju ploceus_2000 at yahoo.com
Wed Sep 8 00:26:13 UTC 2004
Hi.
I'm trying to compile RTEMS for i386.   I downloaded
the files recommended by EPICS website.  I was able
to complete binutils-2.13.2.1 and gcc-3.2.3
compile (with patches applied).
The following error occurs when I compile rtems-4.6.1
and I can't make much from the error reported.
I'm using RH FC2 Linux with native compiler gcc3.3.3
Can anyone tell me what the error is and what I
should do to fix?
gmake[6]: Entering directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c/i386ex/tests/samples/base_mp'
gmake[6]: Nothing to be done for `all-am'.
gmake[6]: Leaving directory
gmake[5]: Leaving directory
Making all in cdtest
gmake[5]: Entering directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c/i386ex/tests/samples/cdtest'
mkdir o-optimize
i386-rtems-gcc --pipe -B../../../../../lib/
-B../../../../../i386ex/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.6.1\"
-DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.6.1\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\"
-isystem ../../../../../i386ex/lib/include
-msoft-float  -O4 -g -Wall -ansi -fasm  -o
o-optimize/init.o -c
../../../../../../../c/src/tests/samples/cdtest/init.c
i386-rtems-g++ -B../../../../../lib/
o-optimize/main.o -c
../../../../../../../c/src/tests/samples/cdtest/main.cc
o-optimize/cdtest.exe  o-optimize/init.o
o-optimize/main.o
/opt/rtems/lib/gcc-lib/i386-rtems/3.2.3/../../../../i386-rtems/bin/ld:
section .initial [03ff1920 -> 03ff1b58] overlaps
section .gcc_except_table [03ff1920 -> 03ff1a2d]
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/cdtest.exe] Error 1
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c/i386ex/tests/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c/i386ex/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c/i386ex'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/home/ju/rtems-gcc/rtems-4.6.1/build/i386-rtems/c'
make: *** [all-recursive] Error 1
[ju at kkachi build]$
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
