[PATCH] if_fxp: do not initialize PCI bus itself
Karel Gardas kgardas at objectsecurity.com
Thu Aug 18 19:04:24 UTC 2005
Hello,
if_fxp NIC driver worked well on pc386 BSP, since it initializes PCI bus
itself. Experts here pointed out that this is wrong way early this year
and I've finally removed this initialization from the driver and tested
that it still works with the pc386 BSP with previous PCI bus init patch
applied. Hopefuly this is also right for other supported platforms.
Cheers,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
Index: c/src/ChangeLog
RCS file: /usr1/CVS/rtems/c/src/ChangeLog,v
retrieving revision 1.259
diff -u -r1.259 ChangeLog
--- c/src/ChangeLog	15 Aug 2005 13:54:15 -0000	1.259
+++ c/src/ChangeLog	18 Aug 2005 18:51:16 -0000
@@ -1,3 +1,7 @@
+2005-08-18  Karel Gardas  <kgardas at objectsecurity.com>
+	* libchip/network/if_fxp.c: Remove initialization of PCI bus.
 2005-08-15	Ralf Corsepius <ralf.corsepius at rtems.org>
 	* optman/Makefile.am: Add preinstall.am.
Index: c/src/libchip/network/if_fxp.c
RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_fxp.c,v
retrieving revision 1.16
diff -u -r1.16 if_fxp.c
--- c/src/libchip/network/if_fxp.c	18 Jul 2005 15:42:24 -0000	1.16
+++ c/src/libchip/network/if_fxp.c	18 Aug 2005 18:51:37 -0000
@@ -447,16 +447,6 @@
 	s = splimp();
-	 * init PCI Bios interface...
-	i = pci_initialize();
-	DBGLVL_PRINTK(2,"fxp_attach: pcib_init returned %d\n",i);
-	if (i != PCIB_ERR_SUCCESS) {
-	  device_printf(dev, "could not initialize pci bios interface\n");
-	  return 0;
 	 * find device on pci bus
     { int j; int pbus, pdev, pfun;
