[PATCH] remove PCI bus initialization from the network drivers
Karel Gardas kgardas at objectsecurity.com
Fri Aug 19 19:42:01 UTC 2005
Hello,
as pointed out but Joel and others, lets remove all the PCI bus
initialization from all network drivers at once and then see what happen.
Attached patch tested only by compilation on pc386 BSP, also if_fxp tested
and found working quite well.
Cheers,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
Index: c/src/ChangeLog
RCS file: /usr1/CVS/rtems/c/src/ChangeLog,v
retrieving revision 1.259
diff -u -r1.259 ChangeLog
--- c/src/ChangeLog	15 Aug 2005 13:54:15 -0000	1.259
+++ c/src/ChangeLog	19 Aug 2005 19:35:08 -0000
@@ -1,3 +1,8 @@
+2005-08-18  Karel Gardas  <kgardas at objectsecurity.com>
+	* libchip/network/if_fxp.c, libchip/network/if_dc.c,
+	libchip/network/dec21140.c: Remove initialization of PCI bus.
 2005-08-15	Ralf Corsepius <ralf.corsepius at rtems.org>
 	* optman/Makefile.am: Add preinstall.am.
Index: c/src/libchip/network/dec21140.c
RCS file: /usr1/CVS/rtems/c/src/libchip/network/dec21140.c,v
retrieving revision 1.30
diff -u -r1.30 dec21140.c
--- c/src/libchip/network/dec21140.c	6 May 2005 20:06:17 -0000	1.30
+++ c/src/libchip/network/dec21140.c	19 Aug 2005 19:35:27 -0000
@@ -1027,9 +1027,6 @@
       return 0;
-   if (pci_initialize() != PCIB_ERR_SUCCESS)
-      rtems_panic("dec2114x: Unable to initialize PCI");
     * Find the board
Index: c/src/libchip/network/if_dc.c
RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_dc.c,v
diff -u -r1.2 if_dc.c
--- c/src/libchip/network/if_dc.c	17 Jun 2005 14:32:23 -0000	1.2
+++ c/src/libchip/network/if_dc.c	19 Aug 2005 19:35:35 -0000
@@ -1918,10 +1918,6 @@
 	 * First, find a DEC board
-	if (pci_initialize() == PCIB_ERR_NOTPRESENT) {
-		rtems_panic("PCI BIOS not found !!");
 	sc = &dc_softc_devs[unitNumber - 1];
 	ifp = &sc->arpcom.ac_if;
Index: c/src/libchip/network/if_fxp.c
RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_fxp.c,v
retrieving revision 1.16
diff -u -r1.16 if_fxp.c
--- c/src/libchip/network/if_fxp.c	18 Jul 2005 15:42:24 -0000	1.16
+++ c/src/libchip/network/if_fxp.c	19 Aug 2005 19:35:40 -0000
@@ -447,16 +447,6 @@
 	s = splimp();
-	 * init PCI Bios interface...
-	i = pci_initialize();
-	DBGLVL_PRINTK(2,"fxp_attach: pcib_init returned %d\n",i);
-	if (i != PCIB_ERR_SUCCESS) {
-	  device_printf(dev, "could not initialize pci bios interface\n");
-	  return 0;
 	 * find device on pci bus
     { int j; int pbus, pdev, pfun;
