configure still fails on CVS checkout
emu at ecubics.com emu at ecubics.com
Mon Jun 13 17:12:10 UTC 2005
Hi all,
got the RTEMS versions of autoconf (2.59)& automake (1.95 & patch 20050303), looks better, but still fails :(
cheers & thanks
-------------------- cut -------------------------
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.6.99.1
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking target system type... powerpc-unknown-rtems
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/bash '../../../rtems/tools/build/configure' '--prefix=/tmp/rtemsdocs-4.7.0'
'--host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--disable-posix' '--disable-networking' '--disabl
e-cxx' '--enable-rtemsbsp=ss555' '--target=powerpc-rtems' '--cache-file=/dev/null' '--srcdir=../../
../rtems/tools/build'
checking for i686-pc-cygwin-gcc... i686-pc-cygwin-gcc
checking for C compiler default output file name... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether i686-pc-cygwin-gcc accepts -g... yes
checking for i686-pc-cygwin-gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of i686-pc-cygwin-gcc... gcc3
checking how to run the C preprocessor... i686-pc-cygwin-gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for strerror... yes
checking for strtol... yes
checking for bash... /usr/bin/bash
config.status: creating Makefile
.infig.status: error: cannot find input file: Makefile
configure: error: /bin/bash '../../../rtems/tools/build/configure' failed for tools/build
---------------------- cut --------------------
