Problem compiling RTEMS for edb7312
Frédéric PRACA frederic.praca at freebsd-fr.org
Wed Nov 23 22:07:08 UTC 2005
Hello,
while compiling RTEMS (HEAD version) for the edb7312, I got this error message :
../../../../../../../../rtems/c/src/lib/libbsp/arm/edb7312/../../shared/console.c:
In function 'console_close':
../../../../../../../../rtems/c/src/lib/libbsp/arm/edb7312/../../shared/console.c:134:
error: 'current_tty' undeclared (first use in this function)
error: (Each undeclared identifier is reported only once
error: for each function it appears in.)
gmake[6]: *** [console_rel-console.o] Erreur 1
gmake[6]: Leaving directory
`/home/fred/Dev/RealTime/buildRtems/arm-rtems/c/edb7312/lib/libbsp/arm/edb7312'
gmake[5]: *** [all-recursive] Erreur 1
gmake[5]: Leaving directory
`/home/fred/Dev/RealTime/buildRtems/arm-rtems/c/edb7312/lib/libbsp/arm'
gmake[4]: *** [all-recursive] Erreur 1
gmake[4]: Leaving directory
`/home/fred/Dev/RealTime/buildRtems/arm-rtems/c/edb7312/lib/libbsp'
gmake[3]: *** [all-recursive] Erreur 1
gmake[3]: Leaving directory
`/home/fred/Dev/RealTime/buildRtems/arm-rtems/c/edb7312/lib'
gmake[2]: *** [all-recursive] Erreur 1
gmake[2]: Leaving directory
`/home/fred/Dev/RealTime/buildRtems/arm-rtems/c/edb7312'
gmake[1]: *** [all-recursive] Erreur 1
gmake[1]: Leaving directory `/home/fred/Dev/RealTime/buildRtems/arm-rtems/c'
gmake: *** [all-recursive] Erreur 1
Any idea ?
Fred
