Network problem - header checksum error -
Steve Hunt hunt at alceli.ch
Mon Apr 17 14:23:14 UTC 2006
in_cksum() does work (without the delay).
On Mon, 2006-04-17 at 15:29 +0200, Steve Hunt wrote:
> I have found that by changing file
> cpukit/libnetworking/netinet/ip_output.c - by adding a delay just before
> in_cksum_hdr(ip) - the checksum is correctly calculated and everything
> works!!!! so perhaps the header is still being changed by the driver at
> that time? or is everything in the same thread? perhaps 'ip' is pointing
> directly to the hardware and the registers are not stable???.
> Very strange ...  but I have not have had time to investigate further
> yet - but I will also see if using in_cksum() in place of in_cksum_hdr()
> fixes (hides) the problem.
> As a side issue - I noticed that when my delay was by adding a 'printf'
> I had a quite stable time reported by ping (~2ms) - but when I used
> usleep() the time for ping to return changed in a cyclical and
> predictable way from 10ms to 1mS !!!!! - would this be expected?  I will
> do some more tests.
> By the way, my target system is a pc104+ ... not very fast by modern
> standards.
> Steve Hunt
> On Fri, 2006-04-14 at 18:15 +0200, Steve Hunt wrote:
> > No - it looks like only the header checksum is wrong.
> > On Fri, 2006-04-14 at 16:30 +0200, Sylvain Prestavoine wrote:
> > > ----- Original Message -----
> > > From: "Steve Hunt" <hunt at alceli.ch>
> > > To: <rtems-users at rtems.com>
> > > Sent: Friday, April 14, 2006 2:44 PM
> > > Subject: Network problem - header checksum error -
> > > > I am having a problem getting rtems to run.  I can boot my application
> > > > on my pc104 with rtk8139 network chip using pxe boot and grub.
> > > > However once my application is running (and is therefore now using the
> > > > rtems network stack not the pxe or grub networking) any packets sent
> > > > from my system seem to have incorrect header checksum.
> > > > For instance a ping to the device reports no replies - but ethereal
> > > > 'sniffer' shows the reply packet arriving - but with corrupt header
> > > > checksum.
> > > How are other datas, corrupted or no ?
> > > Perhaps is an endianness problem ?
> > > -Stan
