rtems_timer_create() problem
Sun Shine pengsens at hotmail.com
Fri Mar 24 08:48:58 UTC 2006
Hi, all
I met a problem when using rtems_timer_create() directive.
rtems_task Init(
  rtems_task_argument argument
  rtems_status_code status;
  rtems_id timer_id;
  rtems_name timer_name = rtems_build_name('C','P','U','T');
  status = rtems_timer_create(timer_name,&timer_id);
  if(status!=RTEMS_SUCCESSFUL)
	  printf("\tCreate timer failed with status code %d!\n",status);
  else
	  printf("\tCreate timer %x successfully!\n",timer_id);
  status = rtems_task_delete( RTEMS_SELF );
when I run the app on SPARC, neither "Create timer failed with status code
*!" nor "Create timer * successfully!" is showed to me, why?
Could anyone tell me how to handle the problem?
Thanks a lot.
_________________________________________________________________
免费下载 MSN Explorer:   http://explorer.msn.com/lccn/
