Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed Nov 22 14:50:45 UTC 2006
Joel,
Attached you will find a patch for "my" solution.
Status:
- It is compile clean and can be started on the mbx8xx BSP.
- It contains my proposed solution to restructure the Chain_Control data
structure.
- It also encapsulates all accesses to chain->first and chain->last into
two macros (_Chain_First(hain_ptr) and _Chain_last(chain_ptr)) to make
it easier to modify the implementation infuture.
- I have NOT reviewed it, so the current state is a proposition.
- I am still not yet sure whether my chosen names for the Chain_Control
structure make sense and will be accepted by the community
So, please everybody: have a look at it and give comments.
wkr,
Thomas.
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20061122/c6d51a29/attachment-0001.txt>
