Network won't initialize
robe0413 at flinders.edu.au robe0413 at flinders.edu.au
Mon Sep 4 07:34:46 UTC 2006
Hi everyone,
I've got a pc386 BSP, with a reatlek 8139D network card. I know RTEMS does not
include a driver for this card, but I was able to find one that supposible
works, which I have attached.
The problem is that when I try to initialize the network via
rtems_bsdnet_initialize_network() the system just hangs and does nothing.
The network is being configured by the following header file:
 * Contains the Network configuration for the PC104
 *@AUTHOR David Roberts
 *@DATE 01/09/06
 *@VERSION 1.00
#include <bsp.h>
/* defines and headers for the rtk driver */
//#define __INSIDE_RTEMS_BSD_TCPIP_STACK__
//#define Os_RTEMS
#include "libNICS.h"
#define NETWORK_TASK_PRIORITY 30
#define NETWORK_DRIVER_NAME "rt1"
#define NETWORK_DRIVER_ATTACH rtems_rtk_driver_attach
#define NETWORK_DRIVER_IRQ 11
//#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_NE_driver_attach
static struct rtems_bsdnet_ifconfig netdriver_config = {
  NETWORK_DRIVER_NAME,
  NETWORK_DRIVER_ATTACH,
  NULL, /* next IF */
  NULL, /* BOOTP supplies IP address */
  NULL, /* BOOTP supplies IP net mask */
  NULL, /* Defaults hardware address */
  0,    /* ignore broadcast */
  0,    /* mtu */
  0,    /* rbuf_count */
  0,    /* xbuf_count */
  0,    /* port */
  NETWORK_DRIVER_IRQ, /* irno */
  0    /* bpar */
struct rtems_bsdnet_config rtems_bsdnet_config = {
  &netdriver_config,
  rtems_bsdnet_do_bootp,
  //  NETWORK_TASK_PRIORITY,
  //  256*1024, /* MBUF spze */
  //  512*1024, /* MBUF cluster space */
If anyone has some solution or things I could try I would greatly appriciate it,
as I've been starring at this problem for days with no solution.
Regards,
David Roberts
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20060904/4f671335/attachment.bin>
