memory leak in imfs?
shizheng neversetsun at ustc.edu
Sun Apr 15 14:08:50 UTC 2007
Hi,
When a symlink file of IMFS is created, IMFS_jnode_t->info.sym_link.name
is allocated
 in IMFS_create_node function. But the memory isn't freed when
IMFS_rmnod is called.
int IMFS_rmnod(
  rtems_filesystem_location_info_t      *pathloc       /* IN */
  if ( !rtems_libio_is_file_open( the_jnode ) && (the_jnode->st_nlink <
1) ) {
     * Free memory associated with a memory file.
    free( the_jnode );   /* here only the_jnode is freed, how about the
memory that hold the symlink name??*/
  return 0;
yours, shizheng
