Two UARTS
Aitor.Viana.Sanchez at esa.int Aitor.Viana.Sanchez at esa.int
Fri Aug 31 13:21:56 UTC 2007
could be using the devices /dev/console and /dev/console_b
Cheers
Sent by: rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org
31/08/2007 15:16
To
RTEMS Users <rtems-users at rtems.org>
cc
Subject
Two UARTS
Hi everyone,
I've got, for sure, and stupid question. I am working with the RTEMS for
LEON architecture. I know that the standard output is connected with the
UART1, but I also have an UART2. I would like, from a user application, to
send some trace information out through the UART2...which the easiest way
to do that?
Cheers,
        Aitor
Joel Sherrill <joel.sherrill at oarcorp.com>
30/08/2007 15:39
To
cc
Subject
Re: MacOS Tools
Aitor.Viana.Sanchez at esa.int wrote:
> I tried to install the sparc-rtems-gcc using macports but did not
> work. I don't know whether all the RTEMS related tools listed in the
> macports SVN work properly or not. Does anybody know the status of
> these tools?
I suspect the port files are horribly out of date.  For sure, they do not
distinguish between 4.6, 4.7, and 4.8.  So that's a bad sign.
Here are the tool versions listed in the arm-rtems-gcc Portfile:
gcc 3.2.3
newlib 1.11.0
gcc-${version}-rtems-20030507a.diff
newlib-${newlibversion}-rtems-20030605.diff
That looks suspiciously like an older 4.6 toolset.
$ /opt/rtems-4.6/bin/arm-rtems-gcc --version
arm-rtems-gcc (GCC) 3.2.3 (OAR Corporation
gcc-3.2.3-20040420/newlib-1.11.0-20030605-4)
So it needs to be updated in various ways.
--joel
> Cheers,
> A..
> *Joel Sherrill <joel.sherrill at oarcorp.com>*
> 29/08/2007 20:39
> To
> cc
> Subject
>         MacOS Tools
> Hi,
> I was curious about how to package tools for MacOS and
> went prowling on the web.  I knew about BSD ports but didn't
> know about this site which has a lot of RTEMS ones
> http://svn.macports.org/repository/macports/trunk/dports/cross
> Is someone on this list responsible for them?  They appear to
> be old since the gcc is 3.2.3 and there is no mention of
> rtems 4.7 or 4.8.
> I am hoping this provides a starting point for someone who
> is interested in providing MacOS hosted RTEMS tools.
> --joel
> rtems-users mailing list
> rtems-users at rtems.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20070831/e4ce9e57/attachment-0001.html>
