Paranoia Results on PowerPC
Mon Jul 23 19:42:36 UTC 2007
Hi,
I have been running paranoia on psim and the gen5200
BSP.  Both report the following as a minor flaw:;;;;
Addition/Subtraction neither rounds nor chops.
Sticky bit used incorrectly or not at all.
TEST: lack(s) of guard digits or failure(s) to correctly round or chop
(noted above) count as one flaw in the final tally below
ERROR: Severity: FLAW:  lack(s) of guard digits or failure(s) to
(noted above) count as one flaw in the final tally below.
PASS: lack(s) of guard digits or failure(s) to correctly round or chop
Is this as good at the PowerPC gets?  Is it possible the
FPSCR isn't initialized such that the results are better?
I spotted one online result from a non-GCC compiler which
had the same result on the PowerPC.  So I am suspicious this
is just the way it is.
Does anyone have a PowerPC system to compare against?  I
am especially interested in results from a PowerPC Mac or
UNIX based system.
Thanks.
--joel
