MCF5329EVB BSP
Kirspel, Kevin kevin.kirspel at optimedical.com
Fri Oct 5 17:08:35 UTC 2007
I have almost completed a port to RTEMS of the MCF5329EVB evaluation board
from Freescale.  With this BSP I had to port the YAFFS2 file system to
RTEMS.  I would like to submit the BSP and YAFFS2 port to RTEMS.  The YAFFS2
license is GPL.  I don't know if that is OK with RTEMS.  I would like to do
some robustness testing on the YAFFS2 port.  Does RTEMS have a test
plan/procedure to validate new file systems?
Kevin Kirspel
Opti Medical Systems
Electrical Engineer
235 Hembree Park Drive
Roswell GA 30076
(ph) 770-510-4444 x4568
(fax) 770-510-4445
URL: <http://lists.rtems.org/pipermail/users/attachments/20071005/13db2c30/attachment.html>
