QEMU/GRUB: No multiboot header ,found
Massimo Tipaldi mtipaldi at cgspace.it
Fri Dec 19 09:21:49 UTC 2008
Dear all,
I have installed all the RTEMS tools on Windows, compiled RTEMS 4.9
(--target=i386-rtems and bsp=pc386) and installed QEMU as detailed in:
http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows
http://www.rtems.com/wiki/index.php/QEMU
All these operations went well.
Therefore, I have tried to launch some RTEMS applications by means of
QEMU/GRUB (in this phase I have taken the executable files produced
during the RTEMS compilation phase, placed in /testsuites/samples): this
operation was successfull as well.
After that I have compiled successfully Hello Word by myself
(examples-4.7.99.2.tar.bz2
ftp://ftp.rtems.com/pub/rtems/4.7.99.2/examples-4.7.99.2.tar.bz2
) and put my hello.exe in the folder /testsuites/samples/hello).
With my Hello Word, the GRUB gives me the message "No multiboot header
found".
As far as I have understood, my hello.exe does not have a multiboot header.
How can I overcome this issue? Should I modify somehow my source code or
the makefiles in order to create this multiboot header into my .exe?
Thanks in advance
Massimo Tipaldi
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
