Option -fcref
Leon Pollak leonp at plris.com
Tue Jan 22 17:18:36 UTC 2008
Hello, all.
I am trying to use the rtems-4.9 tool set and have the following problem.
My g++ call always had:
 -Xlinker @/path/to/file/LinkOptions
where LinkOptions contains parameter where I set my own specific linker
parameters:
 -Mmapfile --cref -T linkcmds
It worked fine with rtems-4.7 tool set too. Now, with rtems-4.9 I receive the
following:
cciplus: unrecognized command line option "-fcref"
Removing the --cref from LinkOptions, goes further and '-T' option is not
recognized.
I tried to put "@/..." after -Xlinker - no effect. Putting '' instead makes
the ld to shout that it does not find the '@/path/to/file/LinkOptions' file,
i.e. it searched it with ''.
Why cciplus takes the LinkOpts file?
Thanks ahead.
Leon
