RDBMon for ERC32
Aitor.Viana.Sanchez at esa.int Aitor.Viana.Sanchez at esa.int
Wed Mar 19 14:34:26 UTC 2008
hi,
please find attached a ERC32 monitor I developed some time ago. It is not
actually the RBDmon but does something similar. I also has a SONIC-T
ethernet driver that allows to download the binary or ELF file remotely to
the board and debug by means of GDB using the serial line.
The SONIC-T driver may be replaced with the driver in you board. At that
time I used the Tharsys VME ERC32 board.
To compile it:
/> make xconfig                 # select the options
/> make
In the image/ directory you will find all the images to be used either on
the TSIM simulator or in the real board.
I hope this will help you.
Aitor
"Teng Chee Wan Philip" <tcheewan at ntu.edu.sg>
Sent by: rtems-users-bounces at rtems.org
03/19/2008 01:48 PM
To
<rtems-users at rtems.com>
cc
Subject
RDBMon for ERC32
Does anyone know where I can get a copy of the RDBMon for ERC32 hardware
(and can be compiled with the current RTEMS tools)?
The last it was mentioned seems to be at
http://www.rtems.org/ml/rtems-users/2001/january/msg00001.html and I don't
think the RDBMon is in the RCC compiler system anymore.
regards,
Philip
rtems-users mailing list
http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20080319/3d8f4847/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080319/3d8f4847/attachment.obj>
