Using RTEMS kernel on arm based board - bare bsp
xu ray rayx.cn at gmail.com
Mon May 5 11:07:09 UTC 2008
BSP by default will not out put anything.
You serial port should get:
*** HELLO WORLD TEST ***
Hello World
END OF HELLO WORLD TEST
press any key to restart
That is the same for all ARM ports, some BSP might output debug info when
loading driver. However, I believe yours does not. You might need to check
your console driver's code.
2008/5/5 Vinod Kulkarni <vinodk at tataelxsi.co.in>:
>  Hi,
>     My serial port settings are:
> Baud ¨C 115200
> Data ¨C 8
> Stop ¨C 1
> Parity ¨C None
> Hardware flow control ¨C None
> Software flow control ¨C None
> Could you please tell me what is the expected behavior (I have loaded
> hello.exe file)?
> Regards
> Vinod
> *From:* xu ray [mailto:rayx.cn at gmail.com]
> *Sent:* Monday, May 05, 2008 2:09 PM
> *To:* vinodk at tataelxsi.co.in
> *Cc:* rtems-users at rtems.com
> *Subject:* Re: Using RTEMS kernel on arm based board - bare bsp
> It is not the expected behavior.
> How about your serial port's setting, Rate/Nor/7bit.....
> Hi,
>     I am using arm based board (PXA255 based). I have built RTEMS kernel
> with bare bsp. I have my own boot-loader which is capable of loading the
> kernel. Once I load the kernel I am getting a dot (.) as the output. Could
> you please let me know whether this is the expected behavior?
> Regards
> Vinod
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s) and
> may contain proprietary, confidential or privileged information. If you are
> not the intended recipient, you should not disseminate, distribute or copy
> this e-mail. Please notify the sender immediately and destroy all copies of
> this message and any attachments contained in it. Contact your Administrator
> for further information.
> rtems-users mailing list
> Thanks & Best Regards!
> Ray, Xu
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20080505/e3eb60bb/attachment-0001.html>
