[RFC] ARM multilib changes and switch to EABI version 5
Fri Dec 3 11:02:54 UTC 2010
I modified nearly all linker command files of the ARM BSPs with the exception of:
gba/startup/linkcmds
nds/coproc/coproc.ld
Please check that your BSP works.
The BSPs use now a base linker command file:
shared/startup/linkcmds.base
This eliminated a lot of copy and paste.  This change was necessary as a
preliminary work to switch to the EABI version 5.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
