No accessible timer state?
Ingolf Steinbach ingolf.steinbach at googlemail.com
Tue Mar 30 15:11:16 UTC 2010
2010/3/30 Joel Sherrill <joel.sherrill at oarcorp.com>:
> The rtems_timer_get_information() call does most of this.
> Is it what you want?
Thanks, Joel, that is good news.
>     the_info->the_class  = the_timer->the_class;
>      the_info->initial    = the_timer->Ticker.initial;
>      the_info->start_time = the_timer->Ticker.start_time;
>      the_info->stop_time  = the_timer->Ticker.stop_time;
For the layman (with respect to RTEMS internals), it is not clear how
these elements are to be interpreted. For instance, in which time
scale are "start_time" and "stop_time"? What does "initial" mean?
*Experiments* indicate that "initial" is the duration (in ticks), and
that initially, stop_time = start_time + initial.
At the time of invocation of the TSR, stop_time seems to be 0 -- most
of the time(!) -- so this probably can be used to determine whether
the timer is still running.
However, we have noticed that for the very first invocation of the
TSR, stop_time is non-zero (at least with 4.6.x).
> Please submit a patch for the documentation.
See above, there are several issues which would have to be clarified in advance.
Kind regards
Ingolf
PS: The original question was not intended to be criticism. It had
really not been clear to me whether the documentation had been left
out on purpose or just forgotten.
