Stack full or something else?
João Rasta freakforever at gmail.com
Mon Nov 15 18:13:23 UTC 2010
Hi Joel,
Good point. I have a task that is heavy on memory operations (multi-size
array operations and so on). It also has a lot of doubles so it can also be
corrupting its stack. Too bad it is 'silent' when corrupting the memory one
way or another..
To eliminate the stack overflow issue, i guess it is not enough to increase
the initial task stack size. Is there a way to control the subsequent called
task stack sizes?
Best,
JM
On Mon, Nov 15, 2010 at 5:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 11/15/2010 11:24 AM, João Rasta wrote:
>> After some hard debuggin' with gdb i found out that this error is
>> occurring at _Semaphore_Translate_core_mutex_return_code() but i still don't
>> know why it happens. Here's the disassembly of the code where the error is
>> generated
>> 0x40040d88 <rtems_semaphore_obtain+192>: ld      [ %l3 ], %g1
>> 0x40040d8c <rtems_semaphore_obtain+196>: call    0x400410c8
>> <_Semaphore_Translate_core_mutex_return_code>
>> 0x40040d90 <rtems_semaphore_obtain+200>: ld      [ %g1 + 0x34 ], %o0
>> 0x40040e20 <rtems_semaphore_obtain+344>: b       0x40040d8c
>> 0x40040e24 <rtems_semaphore_obtain+348>: ld      [ %l3 ], %g1
>> 0x40040ed8 <rtems_semaphore_obtain+528>: b       0x40040d8c
>> 0x40040edc <rtems_semaphore_obtain+532>: ld      [ %l3 ], %g1
>> And Stack copy:
>> Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
>> Segmentation fault.)
>>    3 rtems_semaphore_obtain()
>> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
>> 0x40040edc
>>    2 <symbol is not available> 0x00000008
>>    1 <symbol is not available> 0x0000000c
>>  If this is the backtrace, somehow the stack pointer has gotten
> corrupted.
>  The last value i could get from %g1 is 0.
> If this task is not blowing its stack, then we are left with a couple
> of guesses:
> + another task is blowing its stack and corrupting memory
> that impacts this task.
> + stray write is corrupting something.
> When did you see the %g1 have 0?  What was the last instruction?
> Where was it loading from?
>  Here's how i'm configuring semaphores:
>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES            15
>>  This only affects POSIX semaphores sem_XXX.
>> Any hints on what it can be failing? Should i set
>> CONFIGURE_MAXIMUM_SEMAPHORES as well?
>>  I doubt it since you appear to be completing a semaphore_obtain.
> That means (probably) that a semaphore_create worked.
>  Do a backtrace in gdb.  I suspect you will find you are  coming from a
> subsystem
> like termios.
> -joel
>> Best,
>> JM
>> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:
>> joel.sherrill at oarcorp.com>> wrote:
>>    On 11/12/2010 01:05 PM, João Rasta wrote:
>>        Hi Daron,
>>        It is running on a LEON-3. The application exits raising the
>>        following exception:
>>        IU in error mode (tt = 0x07)
>>        which is a memory access to an unaligned address. The last
>>        instruction is this:
>>        4003bd74  d0006034   ld  [%g1 + 0x34], %o0
>>    What is the value of g1?  Is it unaligned?
>>        I don't understand why i have this error. The code where this
>>        error is being reported is compiled independently and then put
>>        in a library, but it uses the same cross-compiler as the main
>>        source code. I don't think i'm doing something wrong while
>>        compiling the library files, i use the same compilation flags..
>>        What can i be missing to have unaligned memory accesses?
>>        Best,
>>        JM
>>        On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
>>        <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
>>        <mailto:daron.chabot at gmail.com>>> wrote:
>>           On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
>>        <freakforever at gmail.com <mailto:freakforever at gmail.com>
>>        <mailto:freakforever at gmail.com>>> wrote:
>>               Hi,
>>               I have an RTEMS POSIX API application which comes to a
>>        point
>>               that if a small function (with some doubles passed as
>>               arguments) is called, the application exits with an
>>        error. At
>>               first i thought of increasing the stack space. I did
>>        this with
>>               CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
>>        remains
>>               even if i remove all the contents of the function.
>>               1) Am i setting up the stack size correctly? I think i
>>        am, but
>>               i ask just in case..
>>               2) Is there any other explanation to why a function call
>>               crashes the application besides having a full stack?
>>        Again, i
>>               erased the function contents..
>>           What architecture is this running on ?
>>           What is the application exit error (message and/or return
>>        code)?
>>           It looks like all POSIX threads are created as floating-point
>>           tasks (FP state saved across context switches), so there
>>           "shouldn't" be a problem on that aspect...
>>               Best,
>>               JM
>>               _______________________________________________
>>               rtems-users mailing list
>>        rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>        <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>>        http://www.rtems.org/mailman/listinfo/rtems-users
>>    --     Joel Sherrill, Ph.D.             Director of Research&
>>  Development
>>    joel.sherrill at OARcorp.com        On-Line Applications Research
>>    Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>      Support Available             (256) 722-9985
> Joel Sherrill, Ph.D.             Director of Research&  Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20101115/e19455f6/attachment-0001.html>
