Yet more MinGW Build Issues
Sam Lost slostuk at gmail.com
Thu Oct 21 05:35:56 UTC 2010
I issued the following commands
I have been unable to download and bootstrap the 4.10 source so in order to
get something working I downloaded 4.9.4
../rtems-4.9.4/configure --target=powerpc-rtems4.10 --enable-rtemsbsp=psim
enable-cxx --enable-test=samples
make install
I have attached the config.log file
Regards
William
On Thu, Oct 21, 2010 at 1:57 AM, Ian Caddy <ianc at goanna.iinet.net.au> wrote:
> Sam,
> On 20/10/2010 11:51 PM, Sam Lost wrote:
>> After a bit of a battle I have managed to install the RTEMS MinGW tools.
>> I have been using the following document as a guide along with a lot of
>> help from Ian (Many Thanks):
>> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows#MSYS_-_M4
>> I have followed the directions for MSYS however when I run make install
>> I get the following errors:
>> make[2]: *** No rule to make target `install'.Stop.
>> make[1]: *** [install-recursive] Error 1
>> make: *** [install-recursive] Error 1
>> Any ideas what might have gone wrong?
> What steps exactly did you perform to try to build RTEMS?
> What was your configure command?
> Can you provide the config.log?
> We need more details here to be able to help.
> regards,
> Ian C.
> Ian Caddy
> Goanna Technologies Pty Ltd
> +61 8 9444 2634
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/671ae765/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/671ae765/attachment-0001.obj>
