gcov question
Aitor.Viana.Sanchez at esa.int Aitor.Viana.Sanchez at esa.int
Wed Sep 15 13:02:16 UTC 2010
Hi Mariana,
happy to hear that. If you have performed any mods on the code would you
please forward them to me in, say source code or patch format?
Regards,
Aitor
Mariana Solaro <msolaro at invap.com.ar>
To:
Cc:
rtems-users at rtems.org, rtems-users-bounces at rtems.org
Date:
09/15/2010 02:59 PM
Subject:
Re: gcov question
Hello Aitor, thank you very much for your help. We used what you gave us,
and it finally worked.
We are measuring the coverage using the TSIM and using the real hardware.
Best regards,
Mariana
El 02/09/2010 11:56 a.m., Aitor.Viana.Sanchez at esa.int escribió:
Hi Mariana,
When you compile your code with -ftest-coverage and -fprofile-arcs the
compiler analyses and divides the compiled code into basic blocks. Those
blocks are one or more lines of code and each of them has a counter, added
also by the compiler. The compiled code is also instrumented with some
assembly code in order to increase the basic block counters.
The __gcov_init and __gcov_merge_add functions (among others) are missing
from the RTEMS toolchain so need to be implemented (or borrow from the
libgcov.c as they are pretty standard). The only problem you may face is
that the libgcov standard library is implemented for non-embedded systems
which means that the counters and coverage information is dumped from time
to time to the proper files. In ERC32 (embedded system) you won't have
that capability so you'll have to modify (re-implement) some of the
functions. In particular gcov_init() and gcov_exit() to store the info in
local memory and flush it off a e.g. serial line.
On the other side you'll need an application that interprets the data and
generages the gcov files.
I already did that exercise some time ago for LEON2 processor (pretty
similar to ERC32) and I attach to this email the source code.
This source code has the following directory tree:
arch -> all the architecture dependent code
build -> build directory
include -> header files directory
lib -> standard libgcov.c file
os -> OS dependent code. So far only for RTEMS
samples -> some example programs
tools -> gcov-iov version generator tool
If you look into the arch directory you'll see the sparc sub-directory and
under this both the erc32 and leon2 directories. The erc32 directory and
particulary the if_serial.c file is the one you'll have to modify to make
it work under ERC32. Only four functions need to be implemented
if_serial_init - initialise the serial interface
if_serial_read - read from the serial interface
if_serial_write - write to the serial interface
if_serial_destroy - destroy the serial interface
Implementing those functions and adding to the Makefile the necessary
lines to also compile the erc32 architecture (easy) you'll build a
libgcov_rtems_erc32.a library which you'll link together with your
application under coverage testing.
In the directory e.g samples/bubble you'll find the the lcov.sh script.
Which contains all the necessary commands to compile the bubble.c
application, link it with the libcov_rtems_xxx.a library, execute it under
TSIM and then analyse the results.
I did not get into too much detail regarding the GCOV functionality. The
source code attached is working and I have used it with RTEMS 4.8 and
LEON2 under both TSIM and real hardware using the RS232 port.
With regard to GPROF, also some code needs to be implemented. I already
started a gprof implementation for leon2 and RTEMS 4.8 but its still not
working 100% properly. If you want I can also send it to you.
Hope this helps
Aitor
Sent by: rtems-users-bounces at rtems.org
09/02/2010 03:42 PM
To
cc
Subject
gcov question
Hello, I have a question about gcov an how to use it.
We are using the sparc ERC32 processor, and the RTEMS 4.10 version.
We've seen that there is a tool called gcov that allows it to measure
the tests coverage. We don´t know exactly how to use it with RTEMS. We
already try to compile the source code with the -ftest-coverage and
-fprofile-arcs options, but it only generates the .gcno files, and not
the .gcda files, so when using gcov, the coverage indicated is 0%.
When the linker starts it says that it can't find the __gcov_init and
__gcov_merge_add functions.
So, I would like to know how to use the gcov and gprof tools with RTEMS
if it is posible.
Thank You!
Bye
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20100915/4d2a9892/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100915/4d2a9892/attachment-0001.jpe>
