Connection to bugzilla is untrusted ?
Kate Feng feng at bnl.gov
Fri Apr 27 14:08:10 UTC 2012
Hi,
   Whenever I try to access the site at
https://www.rtems.org/bugzilla/show_bug.cgi?
I always recevie the message below.  Some people told me that
they could not access it.  Thankfully, it is always OK with other RTEMS
sites.
Could the link connection for bugzilla be fixed, please ?  Please advise.
This Connection is Untrusted
           You have asked Firefox to connect
securely to www.rtems.org, but we can't confirm that your connection is
secure.
           Normally, when you try to connect securely,
sites will present trusted identification to prove that you are
going to the right place. However, this site's identity can't be verified.
www.rtems.org uses an invalid security certificate.
The certificate is not trusted because it is self-signed.
The certificate is only valid for rtems.org
(Error code: sec_error_untrusted_issuer)
Regards,
Kate Feng
