More on File system and CompactFlash on MCF5485EVB board
Chris Xenophontos cxenophontos at hammers.com
Fri Dec 14 22:25:12 UTC 2012
We usually unmount the card properly, however this seems to have no affect.
How can I determine if my driver protects against concurrent access?
We took \libbsp\powerpc\mbx8xx\ide\pcmcia_ide.c and modified it access our
specific hardware.
On Fri, Dec 14, 2012 at 2:14 PM, Sebastian Huber <
> On 14/12/12 17:31, Chris Xenophontos wrote:
>> However, when removing compact flash card from target, and reading it on a
>> PC, tstfil2 seems to have a 512-byte block that is corrupted
> Do you unmount the file system before you remove the card?
> Has your driver protection from concurrent access?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121214/9a05b30d/attachment-0001.html>
