Error in Installing Autotools 4.10
Binkowski, Cassio cassioiks at gmail.com
Sat Feb 25 18:49:26 UTC 2012
On Sat, Feb 25, 2012 at 3:42 PM, Andrei Chichak <groups at chichak.ca> wrote:
> On 2012-February-25, at 9:22 AM, Binkowski, Cassio wrote:
> On Sat, Feb 25, 2012 at 2:03 AM, Ralf Corsepius <ralf.corsepius at rtems.org>wrote:
>> On 02/25/2012 12:07 AM, Binkowski, Cassio wrote:
>>  Is all I need to get it running:
>>>  * MinGW;
>>>  * MSYS;
>>>  * http://www.rtems.org/ftp/pub/**rtems/4.10.2/rtems-4.10.2.tar.**bz2<http://www.rtems.org/ftp/pub/rtems/4.10.2/rtems-4.10.2.tar.bz2>
>>>  * Autoconf and Automake;
>> Prebuilt packages available from here:
>> ftp://ftp.rtems.org/pub/rtems/**mingw32/4.10/rtems-4.10-**autoconf/<ftp://ftp.rtems.org/pub/rtems/mingw32/4.10/rtems-4.10-autoconf/>
>> ftp://ftp.rtems.org/pub/rtems/**mingw32/4.10/rtems-4.10-**automake/<ftp://ftp.rtems.org/pub/rtems/mingw32/4.10/rtems-4.10-automake/>
> I didn't find any instructions on how to build these manually? Can you
> please provide such information?
> The instructions for those are on Chris' mingw page
> http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows
> …but, download the bz2 file from those directories that don't have -src in
> their names. Then
> cd /c
> tar xvfj thenameofyourfile.bz2
> And it will extract the pieces into the proper places.
Don't I have to make or compile them for them to be functional (whatever
their function is)?
>>   * Respective tools for specific CPU?
>> Yes, at minimum you need the binutils and gcc packages for your the
>> target. Prebuilt packages also available from here:
>> ftp://ftp.rtems.org/pub/rtems/**mingw32/4.10/rtems-4.10-<ftp://ftp.rtems.org/pub/rtems/mingw32/4.10/rtems-4.10->
>> <**target>-binutils/
>> <**target>-gcc/
> Why are you referring to the 4.10 tools? Shouldn't we be using 4.11
> already?
> A darn good question, and one that has been much on my mind.  Ralf?
> Once you get all of the appropriate pieces in place, it still won't
> compile according to the instructions. You have to do a
> bootstrap
> in the directory that has the RTEMS source. A side effect of this is that
> the "configure" script will be created. Only then can you use the
> "configure" command.
> That's as far as I got. I am having major issues with the "make" step not
> knowing how to make "all".
Ok. How do I "bootstrap" it?
> Andrei
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20120225/1dc68781/attachment-0001.html>
