write data to the address (PC104)--solved
zhoupeng zpeng563 at 126.com
Sun Jul 1 08:25:31 UTC 2012
Recently , I want to write data to register of can device. At first I use IO space , so I can't make the device operated. Later, I change to use memory space. I can send data and receive data from the register.
IO space:
 两个最基本的SJA1000寄存器读写函数
/*unsigned char read_sja(unsigned char RegNum)
 unsigned char bValue;
 RegNum &= 0x7F;      //最高位清0
 inport_byte(BASE_ADDRESS+RegNum,bValue);
 return (bValue);
void write_sja(unsigned char RegNum, unsigned char bValue)
 outport_byte(BASE_ADDRESS+RegNum,bValue);
 delay(50000);
memory space:
 unsigned char data;
 RegNum &= 0x7F;
 data =  * (volatile unsigned char *)((BASE_ADDRESS)+RegNum);
 return (data);
void write_sja(unsigned char RegNum, unsigned char data)
 RegNum &= 0x7F;
 * (volatile unsigned char *)((BASE_ADDRESS)+RegNum) = data;
By the way , not all the PC-104 have can module. If you PC-104 have can module, you can follow the manual. But you must  find out if the operation of register is IO space or memory space.
URL: <http://lists.rtems.org/pipermail/users/attachments/20120701/f98c0ca0/attachment.html>
